Results 1 to 8 of 8
Thread: Bad shaking through the steering wheel
    06 VE SS
    May 2009
    Rockingham, WA
    Question Bad shaking through the steering wheel
    G'day all I have a 93 vp v6 with a Sre v6 race engine in it less that 10,000kms on the clock.
    When you take of hard and get to about a 100kms the car get a very bad shaking through the steering wheel ,but if you take off normaly you dont get the shaking through the steering wheel .can anyone help? its piss'in me off big time.
    oh iam just putting the little smiley face waxing in because its cool
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    could be few things, warped rotors, first bet would be tightening up all tyres
    VP Exec
    Mar 2009
    Melbourne, bayswater
    By the sounds of it you need a wheel balance. My brother had the exact same problem. As soon as he hit 100kms the steering wheel would shake, and when he was hitting around 140kms the wheel was just going crazey. Went and got a wheel balance and it was perfect. No vibrating or shaking what so ever.
    VL Executive
    Feb 2009
    Craigmore SA
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    or tie rod ends, when i was driving around in one of my cars the tierod ends are fully gone . rattles like a bitch, just go through and check all the ball joints, tie rod ends, front strut insert nuts. also while the car is on the ground grab the top of the wheels and pull and push violently and see if u get any rattles
    06 VE SS
    May 2009
    Rockingham, WA
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Outer tie rod end's... jack up the front of your car til the front wheels are off the ground and grab a hold of the wheel and try and move it around... if it feels like the wheel is loose and not on properly it your outer tie rod end's...
    good luck mate.. if it is those get it fixed ASAP.. it the joint breaks apart = BIG trouble...
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    wheel balance bugged front end bearings tie rod end's warped disk will cause all those issues good luck
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. Steering Wheel Shaking from 90km onwards
    By speedyvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2008, 06:48 PM
  2. shaking steering wheel
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2007, 05:48 PM
  3. wheel shaking when braking
    By dewso_18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2006, 06:47 PM
  4. Shaking Steering
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2006, 06:55 PM
  5. steering wheel shaking at 80+ Km/h
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2005, 07:44 PM
