Going to change the Fuel pump (possibly shagged) and sender unit in my VN wag (its leaking).
The replacement is from a VR wag, hence the return line is part of the sender unit. Is it ok to just plug up the return line into the sender unit, and allow the fuel to return via the hose it originally does in VN's (i.e a few inches to the side of the sender)
is it worth it and/ or better to be done with it and just get the whole VR tank?
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
