Results 1 to 10 of 10
Thread: Vn keeps dien!
    VN Calais
    Jun 2009
    New Zealand
    Exclamation Vn keeps dien!
    Hey there
    My car desided to die on me the other day so i checked it out. Thinking it was the crank angle sensor so i replaced that and it ran good for a day and then died again
    it now has code 14?? and won't go at all
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    12 Normal Operation (System Pass)
    13 Oxygen Sensor (O2) or Circuit
    14 Coolant Temperature Sensor – Voltage Too Low
    15 Coolant Temperature Sensor – Voltage Too High
    16 Coolant Temperature Sensor – Voltage Unstable
    17 PCM Coolant Temperature Circuit
    18 n/a
    19 Throttle Position Sensor
    20 n/a
    21 As above – Voltage Too High
    22 As above – Voltage Too Low
    23 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Too Hig
    24 Vehicle Speed Sensor or Circuit
    25 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Too Low
    26 MAS (Manifold Air Temperature) Sensor or Circuit – Voltage Unstable
    27 n/a
    28 Transmission problem (get wallet out, yippee heaps of money
    29 n/a
    30 n/a
    31 Theft Deterrent System – Missing Signal
    32 MAF (Manifold Airflow) Sensor or Circuit
    33 MAP (Manifold Absolute Pressure) Sensor or Circuit – Voltage Too Hig
    34 As Above – Voltage Too Low
    35 Idle Speed Error
    36 Vacuum Leak
    37 n/a
    38 n/a
    39 n/a
    40 n/a
    41 Crank Angle Sensor
    42 EST (Electronic Start Timing) Circuit
    43 Knock Sensor Circuit
    44 O2 (Oxygen) Sensor – Lean
    45 O2 (Oxygen) Sensor – Rich
    46 No Reference Signal From Ignition Module While Cranking
    47 No 18x Reference Signal From Ignition Module
    48 Camshaft Position Signal Missing
    49 Camshaft / Crank Signal Intermittent
    51 MEMCAL PROM Error - Check insertion of MEMCAL in socket and bent pins.
    52 CALPAK Error - Check that CALPAK is in place, fully inserted, and no bent pins.
    53 System Over-voltage - Car's alternator has produced >17.1 volts for over 2 seconds. Check charging system
    55 ECM A to D Error - Check ECM grounds, or excessive input voltage
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    14 wont be the stalling - most of the time it will be the DFI/ECU or coils
    VN Calais
    Jun 2009
    New Zealand
    I took the coils off the dfi and i have 12v at all the 4 wires with the ignition on, and have 13ohms across all the coils
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by dazza 38 View Post
    Then I'd maybe sus out an ECU that you could try for a while.
    VN Calais
    Jun 2009
    New Zealand
    sorry forgot to say when i crank it i have no spark as well....
    88GreenVN's Avatar
    Jun 2006
    check the lock in the glovebox - it's prone to losing contact and this kills the spark
    wriggle it a bit with flat blade screw driver while cranking the motor
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the balancer hasnt rubbed on the cas and killed it also make sure you are getting 12 volts to the dfi
    VN Calais
    Jun 2009
    New Zealand
    Quote Originally Posted by 88GreenVN View Post
    tried this and had no luck
    VN Calais
    Jun 2009
    New Zealand
    Quote Originally Posted by delcowizzid View Post
    Am I able to check the cas with it still on the car? should i be able to get a voltage or something out of the sensor?? and i checked the dfi again and i do have 12 vovts going there and though to the coils.. put my test light onto the wires feeding the coils and it has a constant 12volts should it pulse when i crank it over??
