it keeps randomly stopping with the engine light on . it does not happen at a certain temp or speed just random , we took chip out n put back in and seemed fine . had no code . but then on way to work thismorn it happened again , engine light came on , gave it a rev n carried on as it didnt stop fully this time . so lost
checked the fault codes?
yea came up with nothing
Several things can give the "random stall"
Coils/DFI (most common)
CAS (normally hard to start wor a while)
ECU (least common)
Start with those - swap the dfi/coils with a mate if you can.
and 3 Dangerous non ABS VN's
