Results 1 to 14 of 14
Thread: battery light not coming on
    vt exective
    Oct 2006
    Default battery light not coming on
    I have a VN Calais and last week the battery light stopped coming on . Have changed the globe in dash.alternator starter moter.battery .just want to know if any one else has had this probem and can i fix it thanks
  2. Default
    what do you mean it's not coming on? when you first hit the ignition? or when driving? it's not meant to come on when driving, so your problem is already fixed
    Quote Originally Posted by zai View Post
    I am not sutpid
    vt exective
    Oct 2006
    Quote Originally Posted by levymetal View Post
    Very F____ funny yes i ment when you first turn the ignition on .go have a smarty hehehe
    it was the brown wire from the altenator it was broken and thats why the light was not coming on so all fixed now .i hope this helps anyone that has the same problem...
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Sorry to bump an old thread, but I have the same problem and the brown wire is not broken. And the battery light (when the ignition is first turned on) was working before I changed the alternator which has a new regulator with new brushes on it.
    Tested with a multimeter and only getting 12.3 on idle.
    Could the new regulator cause this problem or is there something else I should check?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    turn the key to reds and check that the brown and the white and the big red wire all show 12v
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Cheers for info
    The main has 12 volts. But there is no 12v on the brown or white I am confused at this point... I was hoping it was not the regulator.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you have the regulator plug not plugged in do it without it plugged in.if there is still no power on the white wire there is a fusable link by the battery for it trace the wire there is a slightly fatter flexiable wire it plugs into at the battery about 70mm long.the brown goes to the battery light
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Thanks. Will check all that today. At least that way I do not have to put the old regulator back on
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Ok there is 12v on the white and the brown, so without a doubt the new regulator is a dud....
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah reg or the actual windings in the alternator itself
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Yes that’s true... I doubt two alternators would have bad windings... Getting a new Bosh regulator this Thursday.
    Could bad windings cause the regulator to break? The one I brought from the wreckers was returned because of a faulty regulator and they put another one in it while I was there.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ive swapped regs on lots of them before and no better the windings are prone to dieing as well
    в∞ѕтεכ √&
    Jul 2008
    NZ
    mine actually has a stone damned between the reg and the fuel rail to make the brushes touch at the moment after the charge light came on LOL
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Ok windings are fine... Put another regulator in and all is good if not better than it was before.
    Getting 14.10v at the battery
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  3. drivetrain light coming on
    By mish22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 12:44 PM
  4. Spd Light Coming On
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-07-2006, 12:04 AM
  5. Battery light coming on
    By White202 in forum Electrical Wiring / Questions
    Last Post: 04-09-2005, 07:43 PM
