Hi guys
I brought a rolling VP shell and I have put my 3.8 with auto trans into the shell. The problem I have come across now is that I cant get the driveshaft into the trans. The bolts on the diff flange are pretty rusted. I stopped trying when I was starting to strip the nuts. Can you give me some tips on how to get the drive shaft yoke into the gearbox??
drop the diff............... you could try undoing the bolts on the ceter bearing, geting the handbrake cable outa the way and manuvering the tail shaft till it bends on the uni's the way u want it.
easy'st way is to remove those 4 rusted bolts and replace them.
were you trying to turn the actual nuts or the bolts cause the nuts lock in and wont undo untill the bolts are a fair way out
