Hey Guys, Im new to the forums as i just brought a VP SS in a Manual. Ive just realized the Manual Gear Stick is really Loose? (Up and down NOT side to side), i Tightened up the 2 bolts at the bottom of the stick with an alan key, but after 3 mins of driving it, it started getting loose again?
Any help on this problem will be much appreciated.
Thanks in Advance!
have the bolts become loose again? use loctite
Yes mate, they were, locktite? My mates punching himself for not thinking of that lol. Cheers mate.
Out of curiosity, is there anyway anyone knows of to Fix it without using adhesive?
Just incase i ever need to loosen or take out the bolts again
loctite isnt an adhesive. if it was you may as well use superglue lol. removing it in the future wont be a problem.
have a look at which thread is worn first. if its just the bolts then you can probably get new ones.
Oh, its not an adhesive? Oh sweet, best case scenario is that the bolts are worn like you said ill go to bursons tomorrow and get new bolts and see if that helps, if not Loctite it is!!![]()
Much appreciated guys.
mine was having a problem like this so bad that one screw came out when i was driving, scare as.
so yeah, used locktite and allso put a cable tie on really dight between both screws, that way if it comes loose i'll have a bit of control over it still
Alllllso had the same problem. I ended up buying a pack of the bolts just incase (they come in a pack of 3 for some weird reason). Which was a good idea, lost one out the car when it came loose. Now used locktight.
Originally Posted by davway
could be another thing...
The nylon (or whatever they are) bushes in the shifter itself flog out as it's like a ball and socket setup, and the shifter becomes loose in every direction.
I had this problem on my VN. MY cheap fix was to fit another shifter that wasnt thrashed lol. problem solved!
Its usually the bolts, those parts usually stay on, unless you take it off (or your idiot mate takes it off to make you a custom short shifter you didn't even want). After that, there never the same haha
Loctite is a must for keeping those bolts in. Haven't found another way to do it otherwise (also going to a Ripshift they say to use loctite as well)
As for the bush that REV-231 was talking about, I found the best way to solve that problem was to just weld up around the bottom there. Little bit more noisey but I found it gave better feel when changing gears.
Hot Lap Motorsport
pow3rslave... haha that must of been the tink that i heard earlier in the day then.
i re-tightened it up and its fine now, im just waiting for it to come lose again then ill hit it up with the loctite. Supercheap auto or Bursons should have the bolts yeah?
Thanks heaps for your help guys![]()
Yeah they should, just take one in with you. I normally take my bolts to a place near me called national nuts and bolts, they pretty much have everything, but I'm not sure if you will have a place like that locally.
Champ, Cheers, ill keep you guys posted as to weather or not it fixes it!
