Results 1 to 12 of 12
Thread: Electric Window Switch
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default Electric Window Switch
    Hey I think i may need to change the bulbs in my window switch, but I have no idea how it works, Any help is greatly appreciated.
    VX S Pack & LX SL/R 5000
    Apr 2009
    5.0 VQ Statesman
    Jun 2005
    Quote Originally Posted by antelopeslr5000 View Post
    No bulbs in the window switches, they're LED's.
    lots of help mate...
    i would be interested in this too as i want to change the LEDs to blue ones, anyone got any know how?
    thanks
    Jul 2008
    IT wont be easy, ive got an old one that died on me......... seems they would be a pain in the arse to pull apart, then if your extreemly lucky you may get em back together but i dont hold hope in them working again.
    you could paint the light with transparent blue hobby paint lol.
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I too used a buggered one as a test dummy and i found that you don't need to take the whole thing apart just take off the actually switches themselves, inside them there is a soldered in green LED. So painting it wouldn't really be necessary as you could just change the LED to a blue one.. if you can find one that small.
    Jul 2008
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I've been to autobarn, jaycar, radio spares, autobarn repco and none of them have them in the blue.. =/
    5.0 VQ Statesman
    Jun 2005
    does anyone know the size of them and if so is there is a code for it, and if you would need a new resistor etc?
    thanks
    Vt-Brrrlina is online now vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    u wouldnt need a resistor coz its a led already, the resistor is only to know a normal globe down in voltage...
    u can get em from ebay as a last resort but keep checkin ya dick muffs etcc they do sell em they prob to lazy to order em in..
    power windows switched can be pulled apart both ways from the button bit on top - or the whole bottom and top also come apart..
    the 1st way is easier to put back totgether but harder to solder the led... the 2nd way is harder to put back together (lining up the led with a small hole) but easier to solder the led on
    the size is just a 3mm led
    Apr 2009
    Quote Originally Posted by Vt-Brrrlina View Post
    Not quite true. The resistor is used to limit the current to the LED.
    Depending on the replacement LED (i.e. its forward voltage and current requirements), you may need to change the value of the resistor.
    I might stop at a wrecker on the way home from work and see if I can get a switch, pull it apart and have a look.
  11. Default
    i took apart one of my switches, i have no idea why i actually did it, but yeah make sure you do it somewhere where you can easily find parts. i almost lost a couple of bits when it all came apart. also, i think by taking apart the switch completely, you'll end up breaking the connection of the leds? not too sure about this, but on the switch i have neither of the leds work, and i can't remember but they may have been working before i took it apart. or perhaps that was the reason i took it apart, to see if i could fix it. who knows . either way, it's easy to take apart.
    Quote Originally Posted by zai View Post
    I am not sutpid
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Haha yes it is but when you pull the top from the bottom you break a soldered connection.. which im guessing is the led and probably why yours didn't work. I know this because i now have an extra switch because i couldn't figure out how to fix the one i butchered.the buttons themselves actually pop off to see the leds.
  1. VN Electric Window Switch
    By markER717 in forum Electrical Wiring / Questions
    Last Post: 01-07-2009, 04:43 PM
  2. vr, vs rear electric window switch
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2008, 10:11 PM
  3. Electric Window Switch
    By dathro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2008, 09:00 PM
  4. VY Electric window switch into VL !!!!
    By Rogue-VL in forum Electrical Wiring / Questions
    Last Post: 11-07-2006, 06:51 AM
  5. Electric Window switch
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2004, 09:25 PM
