Results 1 to 6 of 6
Thread: vq struts question...
    VQ stato
    Mar 2008
    Default vq struts question...
    i have a problem to remove a nut from top strut nut cant even get it off..its starting to piss me off. just bought super super lows for front. does anyone have ideas ?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Are you trying to remove the nut with the strut out of the car, or in the car?
    Either way, a rattle gun will solve your problem
    The 1972 HQ Kingswood
    VQ stato
    Mar 2008
    yes the top nut inside the car so i can change springs over lol. dont have rattle gun i tired with socket whole farking thing moves..is there any either way use anyting with out rattle gun ?
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    The whole strut is moving? Try put vise grips on them or something, when it makes contact it should either stop strut moving so you can loosen bolt or fall off, depends how tight the nut is/how tight the grips are.
    Morton's Avatar
    May 2006
    Hit it with freeze-and-release, then it it with WD40, then hit it with a butane torch, then smash it with the rattle gun again
    VQ stato
    Mar 2008
    sweet, ill have a ago tonight see how i go this time lol.
  1. Struts
    By southy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-02-2009, 09:49 AM
  2. What struts do you use??
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2009, 07:36 PM
  3. vs struts to vp
    By lukas pukas in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 10:23 PM
  4. 90/10 Struts. Anyone?
    By Dan355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 01:01 AM
  5. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
