Results 1 to 8 of 8
Thread: fuel pump
    06 VE SS
    May 2009
    Rockingham, WA
    Question fuel pump
    G'day all i have a vp v6 with a Powerdyne Supercharger runing @9psi.Would you need to up grade the fule pump?The kit didnt come one,Iam just concerned the motor wont get a enuff fule at the top end.Thank Ian
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    with them little 24lb injectors it should be fine if you were to go bigger yes bigger pump
    06 VE SS
    May 2009
    Rockingham, WA
    в∞ѕтεכ √&
    Jul 2008
    NZ
    at least 36Lb S/C injectors and 044 in-tank pump if you plan on getting serious and keeping it alive
    06 VE SS
    May 2009
    Rockingham, WA
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by delcowizzid View Post
    hay buddy got 42Lb injsctors and 044 in-tank pump put in today.Thanks for your help
    в∞ѕтεכ √&
    Jul 2008
    NZ
    get it all tuned as well
    06 VE SS
    May 2009
    Rockingham, WA
    Hell yes the dyno sheets in here some where she made 248.5hp/185kw@wheels
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
