Can I cut this bit?
So I am installing an amplifier on the back of the rear seats, vertically, on the passenger side, like so (rough demonstration, not installed):
(607KB, 1200x1600)
In order to mount it to some 8 to 12mm MDF, I believe that I need to cut this part away. It is the lip of the metal support for the seat back. Pictures will make more sense.
(550KB, 1200x1600)
(570KB, 1200x1600)
Is it OK/legal to remove this 'lip'? As one can gather from the first picture, the amp needs more room than what is provided by the existing metal. Thus I wish to attach some MDF to extend the flat surface on which I can mount the amp.
If this is not OK/legal, how else could I mount the amp there? It is already a pretty tight fit there.
Thanks all.
<<<< The information went data way! >>>>
