Im interested in converting to climate control, in a VP. I read a thread on the site, but got a little lost in it, as it became quite complicated, and i don't know much about it.
If i was to purchase this-
the wiring loom, control panel, fan resistor, temp sensor, all the actuators, vacum lines, vacume block.
Would it be difficult to install? Apparently i need the actual heater box to suit? Would this come out of a VP Calais?
Thanks to anybody who can help me here![]()
talk to 88greenvn he is your specialilist
It's heater box out and wire in 10 wires for the climate loom. You can also get the loom and heater from the same car and do the complete swap - 2 days work. But not that hard.
Easy way is to get ALL the parts from the same car loom, heater box, controls, sensors, cluster, switch block for L3 dash. If you get it all it's just a swap it all over job.
and 3 Dangerous non ABS VN's
