Results 1 to 5 of 5
Thread: Cutting Out Problems - VP 92
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Thumbs down Cutting Out Problems - VP 92
    OK here is the story -
    when i accelerate around a corner - my car cuts out but not stalls, no matter where on the accelerator you try you just got nothin there. and now it is starting to sort of like stall
    when i got it going it came up with a code
    code 42 - EST - Electronic spark timing
    is that what its doing?
    and what part is faulty?
    let me know thanks
    COMMODORE VP
    Dec 2008
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    dfi/coil pack cas these are the 3 main components that the car designates firing from seeing its when cornering check the plug into the coil pack and the plug on the cas
    and just to be sure is it only around a right hand corner
    either that or ya fuel pump is bugged and loses pressure going around corners also check if ya have a dent in ya tank as it can cause the fuel to run away from the pump
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    COMMODORE VP
    Dec 2008
    Jun 2008
    golden beach
    i haven't done anything yet lol well nothing more most people here at jc would anyway
  1. VN V6 cutting out
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2009, 04:35 PM
  2. Air con cutting in and out VS
    By fuzzy2308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2008, 04:59 PM
  3. VS Series 2 - Startup & Cutting Out Problems - please help!
    By ultra in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2007, 07:23 PM
  4. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
  5. cutting out
    By StatOmaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2006, 09:16 PM
