Results 1 to 16 of 16
Thread: wont start, ideas?
    vn calais, vs clubsport #137
    Jun 2005
    Default wont start, ideas?
    hey guys,
    tonight i went to fire up my calais for the first time in about 8 months. since coming off the road it received new gaskets, YT roller rockers, all new sensors ect.. ect..
    now, tonight i attempted to fire it up, with a small amount of stale fuel left in the tank i just added 5L of BP ultimate thinking i should burn majority of the stale fuel which doesnt get caught in the new filter anyway.
    now it started and was runing for around a minute, had a slight miss in it, it then stalled, i looked around and found two leads around the wrong way, so i corrected this, and went to restart, and now it sounds asif there is no compression. just constantly cranking over and over, no fault being logged. the cranking no matter how long being held for does not increaser or sound like it attempts to fire.
    has anyone ever heard of a H/G poping just like that? as ive heard a few motors with no compression and this sounds just like it.
    i did a quick check through the oil cap while cranking for blow by and can not feel anything excessive, and the oil does not really look fueled. (but light was quite dim).
    i am yet to double check spark and fuel as i ran out of light, but thought id throw it up here and see what anyone has to say about it.
    cheers.
    Jun 2005
    VT spac super6
    Nov 2008
    Riverton sa
    when you say it sounds like it has no compression,, is it turning over faster than usual?
    Jun 2005
    Quote Originally Posted by HARVZ-6 View Post
    slightly yep, and just over and over, not even a cough and splatter.
    VT spac super6
    Nov 2008
    Riverton sa
    hmmm, id just pul the efi relay an pull a couple plugs out.. so what the comp is if youve got a gauge if not see if it feels strong with your finger
    also make sure its got fuel at the rails 5l isnt much,
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    it stopped after u changed some leads around.. sure u got the firing order corect... check that first.... pull each lead check for spark, check if fuel is pumping thru rail././ 5L of fuel is bugger all... put a few more than that in unless it had heaps to start with..
    Jun 2005
    the firing order is correct. ill put a bit more fuel in it tommorrow, the fuel pump is definately priming. and really if it was a lack of fuel itd normally cough and splatter.atm i have none of that.
    Jordan [VN]'s Avatar
    Jordan [VN] is offline VN Thrasher
    VN V6
    Jul 2009
    Western Australia
    I hate my missus VP! I had to borrow it for like 3 weeks for work and during that 3 weeks - it wouldn't start in the morning like 3 times. For no reason it seemed, just would rev up but not turn over. Pile of dogs nuts.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    i did the leads on the wrong plugs and it was a costly mistake. unburnt fuel when into the cat and then ignited. causing the cat to fail and the car wouldnt start. four 15 mm bolts with sum wd40 and check your cat. its more than likely had it
    Set of thongs
    Dec 2005
    Stonedville
    also dont keep cranking it over, you will cook the starter motor and the power leads to it
    Set of thongs
    Dec 2005
    Stonedville
    Jun 2005
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    Just hollow out the cat mate, you dont really need it and it resticts the flow. The environment and global warming is not really on any commodore drivers mind considering there fuel economy.
    Set of thongs
    Dec 2005
    Stonedville
  15. #15
    Jun 2005
    Quote Originally Posted by santoro91 View Post
    your a clown.
  16. #16
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    id say the cat to sounds like its not breathing unless its got no spark that is
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. Need some help...car wont start
    By UN4TOLDVRSS in forum Electrical Wiring / Questions
    Last Post: 05-11-2008, 10:12 PM
  2. Car wont start, what to do?
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2007, 06:19 AM
  3. Help - Car wont start
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 11:01 PM
  4. VL Wont Start
    By boycee in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-04-2007, 10:20 PM
  5. Car wont run on petrol....any ideas????
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2006, 10:39 PM
