+ Reply to Thread
Results 1 to 4 of 4
Thread: Steering wheel vibration, pulsing
    VP Executive V6
    May 2009
    Default Steering wheel vibration, pulsing
    I had a constant steering shake when i was above 80KM/h so i went about trying 2 fix the problem. i did a swap of any part on the front end of my car that looked worn, ball joints, shock mount plates, tie rod ends etc etc etc (all out of a VN i have 4 parts i know the steering in it was fine). basically had the entire front end steering and suspension out (except the rack). then went and got an alignment... now it is really strange my steering wheel does this constantly. It'll start of dead still, slowly build up vibration, slowly the vibration well die and the steering wheel is dead still again... and it just keeps doing it over and over, the higher the speed the worse it vibrates, it is just a constant pulsing through the steering wheel is the best way i can think to describe it.
    So any ideas on what that might be?
    camstatic's Avatar
    camstatic is offline on cruise-control camstatic Berlina
    VP S1 V6 Executive
    May 2006
    Regional SA
    Unbalanced/buckled wheel is usually the culprit, if you haven't done so already, swap the fronts with the backs.
    Brake rotors aren't warped at all? (test by braking and check for pedal pulse/more intense steering shudder)
    Check out my VP right 'ere!
    Jun 2006
    yeah wheels needs balance or tyres worn funny ..
    get all wheels balanced and rotated and wheel alignment ..
    also check tyre pressure ... 36 in all tyres ...
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    VP Executive V6
    May 2009
    cheers 4 fast response, i think my tire pressure is higher than 36 I'll lower it at the gas station next time and yeah I'll swap the tires over. once i have the front quarter panel and front bar back on my car lol (damn kangaroo )
+ Reply to Thread
  1. Steering wheel vibration
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-06-2009, 12:14 AM
  2. vibration throught steering wheel?? high speeds
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2009, 11:24 PM
  3. Vibration Through Steering Wheel
    By DannY_P in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 08:26 AM
  4. slight vibration from steering wheel
    By Takhuma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 08:11 PM
  5. slight vibration from steering wheel
    By Takhuma in forum General
    Last Post: 19-06-2006, 04:16 PM
