Results 1 to 9 of 9
Thread: VP Radiator Support - Removal
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default VP Radiator Support - Removal
    Im going to begin soon, the process of removing almost complete front end panels off a VP. Anyone know what it takes to remove the Rad Support from a VP Calais?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    probably about 6 bolts, and obviously everything that bolts to it, once you try it you'll see what I mean it kind of explains itself when your doing it. start with bumper and guards headlights/indicators, then start removing radiator and such attachments.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Radiator supports are spot welded in so drill out the spot welds and use a chisel for any spots you get stuck on.
    vnss
    Jan 2005
    s.e melb
    why do you need to taake the rad support off?
    have you pranged yiour car?
    cos thats the only time a rad support needs to be replaced, when its too badly damaged to be repaired.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    will be good to know, i neeeda new rad support on mine, damm 4x4 towballs.
    Pretty sure its welded into place near the air box n batt bay
    ________________________________________
    vnss
    Jan 2005
    s.e melb
    post some pics of the damage guys, id like to see what u think is un repairable.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Be warned, the new rad support usually wont go back in. The subframe will have to be pulled back into shape, guaranteed.
    The 1972 HQ Kingswood
    tonza's Avatar
    tonza is offline Beers & Blastbeats
    '02 VX Exec S2
    Aug 2005
    Brisbane, QLD
    yeah mate more often than not, if the radiator support is damaged, theres a good chance there will be rail damage. and yes, they will be spot welded on. good luck mate!
    Let freedom ring with a shotgun blast
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Cheers for the advice guys. Going to get the panel beaters to do that.. and yes, car was in a prang.
  1. radiator support
    By blockhanson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2009, 09:05 AM
  2. VS BT1 Radiator Support Panel.
    By lo-rolla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 07:02 PM
  3. Radiator support panel for VS
    By shumway in forum Parts And Other Items For Sale
    Last Post: 17-02-2007, 11:24 AM
  4. Radiator support panel tag
    By Taz2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2004, 09:45 PM
