I am just wondering if its possible to open up and clean the indicator like I did with my head lights, also might spray the walls and bottoms like I did to my headlights. Will I be able to open them by soaking them in hot water to soften the glue and pull them apart and re-glue them with silicon?
or is there a better/easier way of doing it?
hmmmmmm i was also wonderin
yeah I might try it anyway if no one else seems to know hot water cant do that much dammage if it doesnt work..
Sharp blade to pry apart the glue (it will be all hard and brittle), and then some good sealant to put it back together. I personally used araldyte, with a thin smear of all-clear over the top once cured.
The 1972 HQ Kingswood
What about a good silicon? like the stuff we used to waterproof the canopy on dads hilux?
Whatever you want, mate.
