so yeh, the diff oil has never been changed, the car is just about to hit 210,000kms.Originally Posted by my car
i have the correct oil and amount, i had a look today. There's a rubber filler plug but there's no drain plug, how ya supposed to change it? do i have to remove the whole rear housing?
You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
you just remove the bottom bolt on the back of it. It looks the same as the other 10, but is actually a drain plug.
Nah man, just the bottom bolt![]()
The 1972 HQ Kingswood
mmm. In IRS cars it's just the bottom bolt. I can't remember if that's the same for live axle. I don't believe it is. If it is, I'm an idiot, my rear axle has been in and out more times than I care to remember and I never found a drain plug.
OP, 200,000 with no diff oil change is no big deal at all. My VN had hit well over 500,000km before it got an oil change in the LSD. It still didn't work, so I threw it in the bin and built a minispooled rear axle![]()
WTB: mulberry VN interior parts
It's the other way around. On live axle, it's just the bottom bolt. For IRS, there's a special drain bolt on the driver's side of the housing.![]()
lol wow, I AM an idiot. I pulled my diff apart 3 or 4 times between two bent axles, an axle leak, seized centre bearings, etc.. and never found the drain plug
Ended up getting it built professionally for $650. Shame, it's backlashing already![]()
well, either i have a different diff or you guys are wrong. there's no drain plug, i had to remove the whole rear housing to drain the oil, took a bit of time but yeh, at least i got to see inside the diff.
the oil was greeny metallic brown, with a putrid smell that says in your mouth and nose![]()
lol yep, they'll do that![]()
tranny oil, motor oil, brake fluid etc etc etc. Thats bearable but I really feel sorry for guys who work on diffs all the time. Its a crap smell that stays with you and trust me its not even east to get the smell out of you clothes. Until the wifey comes and does it for ya anyway....
Nup, not easy at all. Use enzymes. LOTS of enzymes. Anything with enzymesand even then, it'll take a few washes. I just use old shitty clothes i can throw out or tear into rags for working on my diff.
