Results 1 to 4 of 4
Thread: electric problems VP
    VP Commodore
    Jul 2009
    Australia
    Question electric problems VP
    I have a problem with the power windows in our VP 1992 Berlina , intermittently the window will not work (usually in the most inopertune times), we have taken it to an auto electrician and he has said bring it back when it doesnt work. Not the best answer sorry. He mentioned it may be the diode on the board, can someone please explain and is it a auto electrician issue or can i just buy replacement switches.
    I also have a problem with the Air Conditioning. Everything works fine with the functions and coolness , but I keep getting a very high pitched nose , seems to be coming from under the dash. It happens more when you accelerate. Any ideas, thats another problem no one seems to be able to fix.
    Do appreciate any advice
    Jun 2006
    power windows not working all the time ...
    could be damaged wire going into door ... hows your battery ??
    reason I ask about your battery is when they start to die they cause all sorts of problems ... on my car my central locking would engage when engine was first started .. but went away after few minutes .. until battery died I did not know what it was .. changed battery with new one and all is well..
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    VP Commodore
    Jul 2009
    Australia
    Quote Originally Posted by aussieghostrider View Post
    The windows work most of the time, just everynow and then they decide to not work , usually when you most need to put them down. Tks for tip , will look at the battery.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Default Try this link
    Illegitimi Non Carborundum
  1. Electric Antenna installation on standard/non Electric ant VN/VP
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2011, 03:38 PM
  2. vt rear electric windows & rear speaker problems
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 05:40 AM
  3. Electric Window Problems
    By Ricko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2007, 08:13 PM
  4. electric problems????
    By paulio in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2005, 11:02 AM
  5. VN Electric Mirror Switch Light Problems
    By achtung in forum Electrical Wiring / Questions
    Last Post: 12-10-2004, 08:10 PM
