Results 1 to 13 of 13
Thread: tire width?
    3.8L S1 VN
    Stick Avalanche Champion!
    Jun 2009
    latrobe valley
    Default tire width?
    hey just curious, whats widest i can legally have my rear wheels?
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    3.8L S1 VN
    Jun 2009
    latrobe valley
    Philthy's Avatar
    Aug 2005
    When you are looking at rims, you will see that they say "17x8", or "15x7" (examples). The first number is the tyre diameter, and the wecond is the width (in inches). So obviously, the wider the rim the wider the tyres you will be able to fit on them.
    When you get wider than *about* 235 or 245 depending on your ride height, you will have troubles with the tyres rubbing on the guards, but with enough money there are ways around almost anything
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Also LEGALLY the front and rear tyre widths must be in a tolerance of us each, from memory its 20mm, but I could be wrong.
    Meaning the rear tyres cant be more then 20mm? wider then the front ones, would be a very bastard thing to get done for unless its an insane difference or an "attitude ticket".
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    3.8L S1 VN
    Jun 2009
    latrobe valley
    ohk, well yeah the centerlines i want are 15x10s or 9s or 8s id rather the 10s, but might go the 9's and make the front the same :/ thanks
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    If you are talking legality wise, then you are only allowed to have the specified tyres and rims as stated on the tyre placard which is located either in the glovebox or on the drivers door pillar. Not many people follow the placard tyre size recommendation, because if they did, then 90% of the modified cars driving around would be deemed unroadworthy. Exactly whether its an offence to use any other size to what the tyre placard recommends Im not certain 100%.
    VN Wagon
    Feb 2005
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If you're thinking about 275s, I guarantee you'll need to get those arches tubbed
    The 1972 HQ Kingswood
    3.8L S1 VN
    Jun 2009
    latrobe valley
    Morton's Avatar
    May 2006
    chopping up the wheel arches of your car, to make them deeper. Often associated with shorter axles to run wheels with big dish
    vn executive 6 cylinder
    Apr 2009
    if you havent got a tubbed vn im pretty sure the widest tire you can fit without rubbing is 235
  1. slashed tire
    By Greekos in forum The Pub
    Last Post: 21-01-2008, 10:04 PM
  2. Tire Pressure!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 06:17 PM
  3. Tire Wear?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2006, 05:06 PM
  4. About Width
    By wilca014 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2006, 07:03 PM
  5. spare tire
    By Kuzzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2006, 12:30 AM
