Results 1 to 4 of 4
Thread: dyno sheet
    06 VE SS
    May 2009
    Rockingham, WA
    Talking dyno sheet
    G'day all got my vp back from the dyno tuner heres the sheet
    3800 Sre v6 with a Powerdyne BD11 Supercharger @ only 5psi this what made@wheels:
    SORRY DYNO SHEEY LOL
    Black VN MANUAL
    Feb 2007
    Top of Vic
    wow that is very impressive, what are the mods done? intercooled aswell?
    ~ VN POWER ~ Click the scales
    06 VE SS
    May 2009
    Rockingham, WA
    thankz mate
    Its a SRE v6 of ebay
    1 X FULLY RECONDITIONED LONG ENGINE .
    REBORED AND HONED TO PERFORMANCE TOLERANCES.
    CRANK GROUND AND LINISHED.BLOCK HOT TANKED,DECKED ,NEW WELSH PLUGS, BLUEPRINTED.
    HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
    SUPPY AND FIT NEW CAM BEARINGS.
    1x Powerdyne BD11 Supercharger with a 6psi pully (no intercooler yet)
    1x 2 Bar Map Sensor
    1x CAPA Memcal
    1 X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
    1 X SET ACL MAIN AND CONROD BEARINGS.
    1 x Clive Roller 228 @50 Hydraulic Cam 3200 to 6700 rpm.
    1 X SET OF PERFORMANCE VALVE SPRINGS AND RETAINERS .
    2x Performance 70 mm throttle body c/o.
    1x Performance chip to suit SUPERCHARGER
    1x Rollmaster Red timing chain and gears SINGLE ROW
    12 x Hydraulic lifters( NEW ! NOT RECO)
    1 x FULL GASKET SET
    1 X SET YELLA TERRA ROLLERS STD RATIO.
    1 X 3500 STALL CONVERTER TO SUIT T700.
    1 X TWIN THROTTLE BODY MANIFOLD
    6 x 6x 42lb green injectors
    Black VN MANUAL
    Feb 2007
    Top of Vic
    got any pictures? have you taken it down the strip yet?, i have a VN V6 with a sc14 on it and pulled 154rwkw on 4.8psi. also how much it all set you back.
  1. Build sheet needed
    By centy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-03-2009, 05:42 PM
  2. car Sticker Sheet
    By The1985divo in forum The Pub
    Last Post: 05-11-2008, 12:26 AM
  3. any 1 have a spec sheet for a cam
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 12:05 PM
  4. Gripe Sheet
    By ClairBear in forum Jokes/Humour
    Last Post: 18-06-2004, 12:27 PM
