Results 1 to 6 of 6
Thread: Major help needed calling help from vn owners
    VN 5 speed LSD
    Jul 2009
    Default Major help needed calling help from vn owners
    Hi guy n girls
    I picked up a riddin of manual vn cheap and decieded to do a manual converison taking engine and box out as one and engine and auto out as one and change the looms over and swap everything over. Everything went sweet until i came time to crank the engine. got spark but no fuel pump no injectors pulsing. I looked at the engine tages both 89 s1 vns but the problem is here vn s1 89 sep is the auto vn with the manual engine and loom connected but in Oct 89 which was the manual vn they used the s2 engine loom in the s1 motor so i have a few problems as the looms have new by passes and are different to the series1 loom. Has anyone had this problem how did you make the maunal s2 loom work on the series 1 loom.
    Sorry if i dont make any sence
    Any help would be much a appreciated
    OK CHANGED LOOM TODAY TOP ORGINAL ONE ON THE OTHER ENGINE SO BOTH RUNNING SAME LOOMS s1 NOW SAME PROBLEM NO POWER TO FUEL PUMP OR INJECTORS WHEN IGNITION IS TURNED ON NOT COMMING ON WILL START ON AERO START SO THERE GOOD SPARK BUT THE FUEL SYSTEM ISNT GETTING POWER ALSO THE ONLY OTHER THING THATS NOT GETTING POWER IS THE ILLLUMATNION NUMBER 7 FUSE UNDER THE DASH EVERYTHING ELSE HAS POWER ? ANY IDEAS MAYBE A PLUG OR A WIRE THAT COULD OF BEEN KNOCKED OFF UNDOING THE STEERING COLLUM>?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    should have just left the loom, and did the conversion i did, and i have a nov loom, it should be fine, to use your old loom, take the other loom off and use the loom you started with. also the computers dont matter either they are the same auto and manual, does it plug in different where the fuses are under the bonnet? and where the computer is aswell in the car?
    ~ VN POWER ~ Click the scales
    Morton's Avatar
    Fairstar the Funship
    May 2006
    yeah, there's no need to change any wiring. Eep!
    The 1972 HQ Kingswood
    VN 5 speed LSD
    Jul 2009
    Hi i have now changed the looms and still the same problem engine cranks will start on aero start so its got spark. but still not hearing the pump come on ignition and there no power to the injectors also there is no power to illumantion under the dash any1 have any ideas? any plug i could of knocked off under the steering collum when putting pedal boxx on ?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by N-SLAP View Post
    Yes. You need to be methodical and check all plugs, fuses and relays. When you turn the car to the "on" position the fuel pump should run for approx 10 sec and switch off unless you turn the key to "start".
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    on the vp there is small black wire that earths to the steering wheel, i couldnt get mine started without connecting it, i only found out coz i did a whole dash out and forgot about it.... maybe check there
  1. calling all vs owners how many km's out of a full tank of fuel.
    By cyborg66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2009, 09:03 PM
  2. calling all Western australian WH ls1 owners!!
    By walesy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2009, 11:18 PM
  3. calling all vr ute owners
    By love the general in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 12:06 AM
  4. Calling all UTE OWNERS
    By savage1987 in forum The Pub
    Last Post: 17-09-2007, 07:43 PM
  5. calling all VS owners......
    By gee38l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2007, 09:06 PM
