Is there an average life span for the coil packs on a VP V6? I removed my plug leads one at a time from the coil pack while the engine was running, and the spark between 2 of the leads was a lot weaker than the rest. Is this a sign they could need replacing, or could it be something else causing it? Finally, looking on Ebay, it seems a full set of coil packs can be purchased used, with a 30 day warranty for around 50 bucks. Is that a resonable price? Some say they include a DFI module, can some one tell me please what that is?
The DFI module is the unit underneath the 3 coils. As for the weak spark I'd be looking up what resistance you should be getting through the windings with an ohm meter.
Check out my VP right 'ere!
at repco, each coil is $50, so x3 - $150
and dfi about $100
cheap coil packs may not be as good as stock, you'd be surprised what difference a decent set makes.
You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
