G'Day all
I have VP V6 Executive Series II. I have just got a full set vp calais doors trims, 4 power window Regulator ,4 wiring harness with all switchs including center console harness. Is there anything more i would need to get/do be for i start ?
if you haven't already get the panel for the centre console.
do u have the box under the steering wheel for all the wiring harness to go back too...the power window controller box???
i thought ya needed a bcm for the windows mod ?
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
nah the vn/vp runs a seperate module. its a pretty straight forward conversion mate. the loom for the regulators should already be in the doors. mine was in my VP. theres a guide on how to fit them in the how to section. check it out if you havnt already.
George
thanks boys for the help ,i think iam all set now![]()
you will need a drill and bit to drill the pop rivets and some more pop rivets to put them in
