Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: wobbly balancer at idle
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Default wobbly balancer at idle
    ive fitted a new balancer a wile ago to the vp/v6 and ive noticed that its quiet wobbly at idle ive talked to jason and he thinks it may be the cause of my bottom end knock as it disappears when driving (anything over 1500 rpm )
    any thoughts and is the wobble normal ?
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    What does it feel like at idle? My VS has a faint knock at idle but i'm not sure what it is. Wondering if my problem may be related.
    Jun 2008
    golden beach
    seems ruff in relation to the knock
    Morton's Avatar
    Fairstar the Funship
    May 2006
    How tightly did you do the crank bolt on the balancer? Should be at least 200nm if you want it to be tight.
    It's also possible that your old balancer, if broken, has moved around enough to cause damage to the front bearing on your crank. If that's the case, prepare to snap a cam
    How bad is the wobble?
    The 1972 HQ Kingswood
    Jun 2008
    golden beach
    not huge maybe 1 cm fluctuations at the very most and i did it by hand as tight as i could probably not tight enough i assumed a bearing at the start
    just checking all possibles first just to make sure before i do a rebuild
    Morton's Avatar
    May 2006
    How long was the breaker bar you used?
    Jun 2008
    golden beach
    1.5 meters (for a truck)
    Jul 2008
    Thats how i did mine, hasent moved on me yet, ( they are ment to self tighten to a certain degree ) i think :P the bastards who did it the first time used red lock tight ! was fun geting it off i tell ya.
    Jun 2008
    golden beach
    ill pull it back off when i get a chance to and inspect it again i just went for a quick drive and it didnt make the noise at all having said that its relay cold out atm
    Jun 2008
    golden beach
    no other theroys ?
    vp series 2
    Jul 2009
    May have wrong balancer on. According to Repco, they list 2 types for vp's. Repco balancer part # hb 1083 for engine #'s up to #127483 and hb1207 for #'s 127484 and greater. I'm not sure what the difference in the balancers is? Hope thats shone some light.
    Regards Col P
    Jun 2006
    The balancer you have is for a series 1 vn engine... or its defective .... or as someone said you didnt tighten it up ..
    if idiot at repco dropped balancer can stuff it ...
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    Jun 2008
    golden beach
    well it was matched for the engine number but i wouldn't put it past the fools picking up the wrong balencer of the shelf
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    you'll know if it's aVNs1 ballancer because it will slip on without much force. the later ballancers are a interference fit and require some force to get on. later model balancers also have the 3 holes for the puller
    have you checked oil pressure? will give a indication of bearing condition. also, what type of oil do you run. if it's to thick it will knock a little on cold start up, if it's to thin it will knock a little when hot
    Body by Holden, Soul by Brock
    the Legend will live forever
  15. #15
    Jun 2008
    golden beach
    Quote Originally Posted by immortality View Post
    well it wasn't easy to put on and it has the 3 holes oil pressure seems fine but i don't have a Gage to test it for the psi its flowing to top end alright and it only seems to knock at idle anytime thanks for the input
  16. #16
    Jun 2006
    I wonder if the balance shaft was stuffed would cause symptoms like u say ?
    Also you put on the car a while ago and was fine but now playing up ?
    I know sometimes high revs can throw balancers weights off and slip ... your mrs lead footed ?
  17. #17
    Jun 2008
    golden beach
    Quote Originally Posted by aussieghostrider View Post
    no its been doing this almost from when i put it on wich was about 300 km ago and i keep the lead footing to the strip and in my race car and the mrs dont drive im the only driver
    i haven't looked into it until now because i assumed it was a Bering on the way out but wanted to make sure before i did a tare down
  18. #18
    Apr 2006
    Auckland NZ
    i don't think the ballance shaft will be the cause of the knocking. seeing as the ballancer is new i doubt it's failed this quickly.
    i'd buy a oil pressure gauge. even a el' cheapo just to see what is happening.
    try taking the ballancer back, claiming it's faulty. at worst they say no
  19. #19
    Jun 2008
    golden beach
    well that will be the next option (taking it back) i still have the original here it only just starter to crack and what not ill put it back on if i can ever find my 24mm socket lol and see if that resolves some noise
  20. #20
    Jun 2008
    golden beach
    can anyone tell me the right bolts needed for the puller ive lost my ones i used last
  21. #21
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    1/4" UNF. You want them to be a good 5-6" long.
    Yeah, thats what she said.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  22. #22
    Jun 2008
    golden beach
    Quote Originally Posted by azzfox View Post
    thanks i owe ya one and thats what who said lol
  23. #23
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    No worries lol was just a joke because it sounded remotely sexual
    My (ex)Ride
  24. #24
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Dont happen to be a fan of "The office"? lol.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  25. #25
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Cant say I am. I only ever watch it when finding it by accident lol
    My (ex)Ride
  1. wobbly gearstick
    By frase in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2009, 05:41 PM
  2. Something wobbly
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2008, 11:38 PM
  3. wobbly speedo needle
    By Lish in forum General
    Last Post: 19-02-2006, 12:55 AM
  4. Changed harmonic balancer, now oil light flickers at idle
    By Whitey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2005, 01:41 PM
  5. Wobbly Front Seats
    By Lost_Pete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 10:13 PM
