Results 1 to 9 of 9
Thread: hub adapter kit
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Default hub adapter kit
    so why do u need a hub adapter kit for vt brakes (for a vp)
    just didnt know this question so hoping someone can shed some light on why you need a hub adapter etc.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    VN/VP: brake rotor has wheel studs on it
    VR/VS/VT: wheel hub has wheel studs on it, brake rotor slides over the studs.
    The 1972 HQ Kingswood
    VN Sedan
    Jan 2007
    Latrobe Valley
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, they have a different offset. And you can't just bolt on a later style hub, you need the specific hub to suit the VN-VP stub axle.
    You can get rotors that will fit the VR VS hub without a spacer ring that fit the VT calipers.
    Visit my Facebook page
    VN Sedan
    Jan 2007
    Latrobe Valley
    Quote Originally Posted by Not_An_Abba_Fan View Post
    thanks for clearing that up for me
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Mines a '99 VS Statesman and as far as i know most series 3 VS Statesman's came with VT brakes like mine, so maybe get the struts and brakes from a late VS Statesman?
    Just an idea.
    VN Sedan
    Jan 2007
    Latrobe Valley
    Quote Originally Posted by Da_rooster1980 View Post
    Just an idea.
    I've got a set of struts from a VP that had ABS brakes....got them cleaned up and painted, just waiting for hubs and brakes now.....by the way rooster, u get that heatshield felt piece out from behind the dash yet?
    vn v8 calais manual
    Dec 2008
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by Nevyn View Post
    What da????
  1. vl serial adapter?
    By berlinabeast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2008, 10:21 PM
  2. rb30 loom adapter to vk
    By vkwalks39 in forum Electrical Wiring / Questions
    Last Post: 02-10-2008, 08:57 PM
  3. Flywheel Adapter
    By lgnd3800 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 11:22 AM
  4. oil filter adapter
    By krawczuk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2005, 03:11 PM
  5. VP oil filter adapter
    By BrianH in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 04:08 AM
