hey guys i just put my motor back in my vn s1 v6 after doing sumpgasket and welsh plugs was running fine before now wen u start it up the drivebelt tensioner jumps up and the car will sumtimes make a loud bang sorta knock sound please help dont wont to pull motor out thanks
I was running at a 90k when the engine check lamps turn on and then the engine turns off after a few minutes... i started the engine and run again. the lights still on. it happens once in a while. I have a new battery and already check the cables... I was wondering what was the possible problem. Appreciate any help... thanks
and 3 Dangerous non ABS VN's
My tensioner jumps up and down due to there being a miss because of inlet manifold gasket ... so I push down on tensioner whilst engines off to make sure its as far down as it will go ... but a firing miss will cause that as well ..
it sounds like you dont have the leads in right firing order !!!
check leads that they are in correct order on coil pack and spark plugs ... and if its not that inlet manifold gaskets gone .... when you put coolant back in after all that work , did you run the engine with the cap off and turn on heater to remove any trapped air ?? if not then the pressure can stuff your inlet manifold gasket ... I know this because I had air pocket and coolant was seeping from out the inlet manifold gasket ...
and to the person saying about engine light always on and stalling ... have you ever had your oxygen sensor and Crank angle sensor replaced ?? also are your spark plugs and leads been replaced in last 4-5 years ?
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
yeh im a second yr aprentice mechanic so i know bout the coolant and bleeding them easier then bleeding a subaru to me the fireing order looks right and but i will double cheack it thanks guys will have a look at it on the weekend wen im at my moms house wear its kept and ill let youse know thanks
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
lol fair enough
