Results 1 to 9 of 9
Thread: cracks in engine covers
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default cracks in engine covers
    I've recently discovered a number of small cracks in my engine covers (VP V6) after degreasing my motor. Are these cracks something to worry about? They don't look too serious, (photo's tommorow if nessacary) ???
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    you probably mean the rocker covers if it's a v6.
    it's not anything i've ever heard of, but you can get a new set for cheap, just don't get series 1 1's they're expensive cos people polish them, also they have a hole for the pcv that you'd need to weld up.
    supercheap sell metal ones that are about 120 bucks a pair, which i don't think is really worth it.
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    being a composite fibre plastic or something, they can be damaged easier than the older alloy covers.
    i've seen it a few times, but its not common as far as i know.
    just get some replacement ones from wreckers, and some new gaskets.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    yeah i've never seen them cracked before, but i definately want to get them replaced if their going to get worse which i think they will. I wouldnt mind the metal ones, but yeah i think their a little over pirced for what they are. I wouldn't mind polishing a set up if i was to replace them, so the series 1 cover's, are they from a VN, or VP? and are they a different material?
    hakhawk's Avatar
    Jan 2005
    series 1 vn only. find a set cheap if you can, take them to someone to weld the pcv hole(or block it up with a bung), get them sandblasted, then polish/get them polished up.
    check out iblown's vs for pics of some polished up.
    you will need series 1 gaskets for them too, as theyre shaped different(but WILL fit on vp heads without a problem)
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    Thanks everyone, i'll have a look around. I'm living in Cairns now, so i need to find out what wreckers are about and so on...
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Welcome to the sunshine state, I was also told that the aftermarket metal ones dont seal very well and a few people have had dramas trying to seal them up and end up swapping back to standard ones. Dont know how true it is and would like to know what experiances people have had with them.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    I haven't heard about that, but interesting to find out if so, before i go and buy a set.. I've heard the aftermarket ones sit a little higher, whether that causes any issues.
    hakhawk's Avatar
    Jan 2005
    i have the aftermarket ones on mine. no height issues to worry about. they use a cork gasket, so its not perfect, they need replacing more often than stock rubber gaskets, but i havent done mine yet(it does weep a bit though)
  1. A question for the plasterers - fixing cracks
    By MasterOfReality in forum The Pub
    Last Post: 29-05-2009, 01:55 PM
  2. VN - VS 5 litre engine covers (top covers only) VIC
    By Cobez in forum Parts And Other Items For Sale
    Last Post: 19-11-2008, 06:49 PM
  3. VT 5ltr Engine Covers with Rocker Covers Air Brushed
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 28-11-2007, 04:09 PM
  4. VT ENGINE COVERS AND ROCKER COVERS(custom airbrushing)5ltr
    Last Post: 15-10-2007, 07:45 PM
  5. Cracks in CAT
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 04:33 PM
