Results 1 to 7 of 7
Thread: clutch plate help
    aussie_cruzin's Avatar
    aussie_cruzin is offline got boost
    T04 turbo r31 skyline
    Jan 2008
    Aussie
    Question clutch plate help
    my mate came over and had a look at my clutch plate since my new motor is going in soon and he said it's buggered and i have no clue what's a good brand for clutch plate's or if i should get a heavy duty one or any other type
    Any help is good..its just a 5 litre with 3.9diff gears so nothing special but would it be better to get heavy duty one cos of the diff gears or it doesn't matter?
    Drop Clutch
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    The diff gears won't change anything, but generally you buy a clutch as a full kit, with disc, throwout bearing, and clutch cover. For a full std kit you're looking at $305, whilst a heavy duty is $400. You can buy the clutch disc separately, but the way Exedy price it's really not worth getting it on it's own.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Jan 2008
    Aussie
    Quote Originally Posted by gslrallysport View Post
    Hi mate,
    Regards,
    Greg
    ohk then i guess i will just get the kit then its not 2 expensive
    would the heavy duty one be worth getting?or will it make the driving shit?
    Drop Clutch
    VZ AWD One Tonner
    Jul 2006
    The heavy duty generally just use the same disc with an uprated pressure plate. Generally the difference is pretty minimal...
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    When i was shopping around for a new clutch for my VN 5L I was told not to go with the HD because the firewall is weak where the outer cable ends, and the extra force exerted by the HD clutch on the cable can cause damage there.
    Jan 2008
    Aussie
    Jun 2006
    Western Aus.
    Only issue you will have when going to a heavy duty is if you dump the clutch... Then the internal's will be in a whole world of pain. T5's don't like abuse, with a standard clutch is allows a bit of slip to avoid shock loading everything.
    Hot Lap Motorsport
  1. [NSW] FS VN-VS T5 V6 clutch and pressure plate
    By Haydz in forum Parts And Other Items For Sale
    Last Post: 19-07-2009, 09:52 PM
  2. [SA] 2nd Hand CLutch Plate + Pressure Plate For Sale Suit VN / VP / VR
    By social in forum Parts And Other Items For Sale
    Last Post: 29-04-2009, 12:10 AM
  3. clutch plate for vn 5 speed box
    By TRICKEDUP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2008, 06:40 PM
  4. Clutch Plate conversion
    By Brownie1986 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2007, 09:21 PM
  5. VS Twin plate clutch
    By Lazin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 11:07 AM
