Results 1 to 6 of 6
Thread: Fuel Sender Delema
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    Default Fuel Sender Delema
    My drama comes from this...
    The current tank has the two hose connections on the sender itself, where the replacement tank has one on the tank, and the other on the sender, I am unsure which hose should connect to the sender itself and which uses the nozzle on the tank.
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    ... Okay, after talking to one of the guys in at autobarn (who seemed to know at least a little something) I now know which hose connects to which, unfortunately it does mean I have another issue.
    The tank and fuel pump/sender unit I picked up are from a VP series 1, where I have a VP series 2 and apparently the ohmages on the sender to the guage are different, and in all likelihoodup, the fuel gauge wont operate, is this correct?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I noticed on my sender it has two hose fittings, but ones blocked off. Which must mean the earlier tanks had the return line connected to the tank itself, and later models on the sender along with the supply.
    As for the different resistance values I cant see that being 100% true. I have a VP cluster in my VN and the fuel gauge works fine even though the VN cluster had the huge gauge and the VP the small one. The only thing that comes to mind would be tank size/shape. Pretty sure theres no difference, unless someone wants to correct me.
    If youre really that concerned about it why not just swap the pump/sender over from the old tank?
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    Quote Originally Posted by azzfox View Post
    This is apparently the case, the tank I picked up has the return line on the tank, where the original I have has the two lines on the sender itself.
    I am tempted to do this, however, drama I have comes from in addition to a massive dent in my stock tank, the fuel gauge does not work, and part of this exercise is to rule out the sender unit as the faulty culprit.
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    In answer to the OP question, earlier tanks used a connector onto the sender unit for the feed line and a return line onto the tank itself. However after VP Series 2 they went for the feed and return lines onto the sender unit itself!
    So to answer ur question, the return line goes onto the tank.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    The only other thing I can suggest is remove both sender units and check the resistance with a multimeter while moving the float/arm to 'empty' and 'full'. Not only will this tell you if they are different, but you will know if one is shagged. Might even get away with laying the tank level on the ground, checking the connector with a multimeter, then flipping the tank upside down and checking again. This will give you empty and full readings (hopefully). Saves pulling things apart.
    My (ex)Ride
  1. VX LPG Fuel Sender
    By deserthead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 09:59 PM
  2. fuel sender problems (i think)
    By bush_basha in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2008, 08:47 PM
  3. wtb fuel sender and assembley
    By ralph_vt in forum Swap / Wanted to Buy / Trade
    Last Post: 29-09-2007, 07:08 PM
  4. Fuel Sender Unit
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 09:48 AM
  5. vl fuel tank sender
    By cydonia1000 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2006, 11:55 AM
