Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Speedo Corrector for T5gearbox and 3.9 diff gears
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Question Speedo Corrector for T5gearbox and 3.9 diff gears
    Ok well i would like to know what the best and cheapest option is for speedo correction, i will be getting 3.9s put in my VN V6 very soon and would like to have the speedo already right so i dont have to go to court anymore .
    Its a T5gearbox and going for 3.9 gears minispooled, i was thinking of putting a jaycar speedo corrector in i think there is a Howto thread around from immortality also a mate told me that i could change the gear on the gearbox and it is around $40 just gotta get the right one, does any1 know anything about this or have done it. also what will i get out of 1st my guess at the limiter set normal, isnt very high like 45ish? any info is great thanx
    ~ VN POWER ~ Click the scales
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can buy the gears but its just easier to change the pulses with the jaycar kit.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Do you know a price and where to get one from>?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Got the gears in and put it all back together, now its making noises like a bearing noise again, i took the wheels off and rotors and put it in gear on axle stands and it sounds like its coming from axel bearing, but they are new, also a vibration aswell shaking the car. any Ideas, prob wont be loud enough for a vid record not sure.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you get the centre shimmed to suit the new gears
    Black VN MANUAL
    Feb 2007
    Top of Vic
    no but is seems tight, i had problems with the pinion the pinion shim as to big and it have play back and forth with nut done up tight, but that is now fixed with a smaller shim, but the center is pretty tight and i dont think another shim could go in, just might need some fine adjusting to suit gears.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip its not the sort of job you can DIY as you need a heap of shims and feeler guages etc to get it right youll chew the teeth on the cogs in no time with it not setup i think it was savage on here cooked his whole diff from incorrect shimming someone did anyway.get a diff place to set it up is allways the best way
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It's only about $150 to get gears installed by a good diff/trans specialist, so I'd get it done right
    The 1972 HQ Kingswood
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    doesnt matter how tight the centre is, your pinion isn't aligned against the crown wheel, i'd say that's the noise right there... this needs to be aligned prior to any x-axis shim alignment.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    going to 3.9's did you do anything to keep the diff cooler? i read somewhere about putting a new finned cover on it to dissipate heat better
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by pow3rslave View Post
    I really don't see how that is necessary...
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Thanx for the replys guys, the noise isnt as bad now, i forgot to put a small shim infront of crown wheel and also used the commodore crush spacer and the pinion is tight now, i will look around for prices to get the diff shimed propper.
    And no i didnt think 3.9s would make a huge difference on heat over the stock gears but if that is the came, a mate has a alloy diff cover plate if that would make a difference. its off a XF.
    May 2005
    .....SE Burbs
    personally i think your fine, it is spinning with an extra 0.82:1... not sure if its worth cooling options, the diff is fairly well ventilated.
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    Black VN MANUAL
    Feb 2007
    Top of Vic
    is there any good additives that could be put into the diff?, some1 told me graffite but dunno.
  15. #15
    Morton's Avatar
    May 2006
    Nulon do a good gear oil additive - G70 I think. It's not essential in a differential, but if you're really keen on smothering your diff in love, it's the best stuff to use imho.
  16. #16
    vn executive 6 cylinder
    Apr 2009
    Morton's Avatar
    May 2006
    Any Burson/Repco/Autobarn I presume. Burson retail a tube for about $19 I think.
  18. #18
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i noticed i have a leak from the seal on the axels they are new seals and put in correct bloody hell, didnt get to drive the car today because my remote for the car ran out of life lol so i was also late to work.
  19. #19
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Got a tube of Nulon additive, $15 hav'nt been able to drive it much as i installed some spits and have a flat battery now lol gonna push start her in the driveway haha.
  20. #20
    в∞ѕтεכ √&
    Jul 2008
    NZ
    a tube of aditive isnt going to fix an incorrectly shimmed centre
  21. #21
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Well looked at the diff abit more and the axle bearings (outer), the cup that the bearing sits in where it gets tapped into the diff moves around, so it could be spinning and doing all type of things, is it suppose to be a tight fit for that cup like it is for the pinion cups?
    i thought they just slide in and out but some1 told me different,
    Under load the diff makes no noise, and there isnt much noise there to begin with, but when i back off or let the car roll from 60-80 down it makes noise, a mate said he had the same problem, and the pulled the pinion out and he said they put a bigger shim in and leant on it more, so it was tighter any thoughts, if not i will take it out put a stocker in and get it shimmed properly or just leave it in the car and take it to a place either way doesnt bother me.
  22. #22
    в∞ѕтεכ √&
    Jul 2008
    NZ
    cups for the bearings do you mean it has tapered roller bearings on the outside ends of the axles with seperate cups like a front wheelbearing does i thought rears were just a 1 peice ball bearing type
  23. #23
    Black VN MANUAL
    Feb 2007
    Top of Vic
    the ones i have are tapered, and slide in and out of the diff housing, so no dout they might spin around to, this could be a problem, as i was told they are suppose to be real tight for the bearing to sit in it, and if its loose i will need another diff and put all my gears and bearings in it.
  24. #24
    VP Executive R-spec
    Jan 2005
    Any car with no deadner 3.45s and UP will make noise, you'll hear it when you back off, the more gears the more noise. Ever heard a old fashioned car/truck with 5:1 gears? you get the idea . The gears will wear out REALLY fast if they are wrong so you will soon know
  25. #25
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the BW78 uses tapered roller bearing for the axles. the outer race slides into the housing but it's not a tight fit, on the other hand it shouldn't be sloppy either. with the axle bolted in there should be a small amount of side play in the axle.
    get the gears set properly or you risk ****ing em quick.
    my diff builder advised me to get a alloy dif cover for mine when i put the gears in. said it will help it run cooler. probably not required for a road car, but cheap insurance for a track day warrior.
    to correct the speedo, check in the howto section for a Jaycar speedo corrector kit "howto"
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Diff gears/speedo change, it can be done by Holden
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2009, 07:48 PM
  2. Speedo corrector
    By AirStrike in forum General
    Last Post: 19-11-2008, 07:21 PM
  3. speedo corrector in vs
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 12:46 PM
  4. diff gears affecting speedo?
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2007, 06:39 PM
  5. diff gears speedo recalibration
    By jdjones in forum V8 Development and Modification
    Last Post: 02-10-2005, 11:31 PM
