Results 1 to 6 of 6
Thread: Brakes?
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Talking Brakes?
    hey guys.. just wondering i got a quote to redo all my brakes ( machine all 4 discs and new pads and a brale fluid flush it cost $600 ) ... i fell on my ass when i saw the price...
    just wondering how i would go about doing it myself... i have heard thet Bendix pads are pretty good and i can get a set of four for $130 and discs i can get DBA normal rotors for $70ea and slotted for $160ea.. i was going to go slotted at front and normal at rear.. ( front slotted more for looks :P )
    now another thing is it easy to replace pads? what do i have to do? how do i take them off and do they fit in buy clips?
    also the rotors i have no idea how to take them off? how do i take them off...
    is it easy to do a brake bleed.. whats involved..
    also when replacing rotors is it necessary to replace all bearings?
    thanks a lot guys.. all replies are greatly appreciated... i have no idea how to do this.. :P
    Smallies's Avatar
    Smallies is offline I hate carnies.
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    Hey man,
    Hope this helps with the pads: VN - VS: Replacing the Brake Pads (Disc Variety)
    This is for VT- VX but may also help you in some ways: How to: Change pads and rotors.
    Im probably not educated enough to tell you how to change the rotors, From what i remember its not difficult at all, but my memory is real fuzzy, so hopefully someone else can tell you. Once you're in there doing your pads, you'll probably see that rotors wont be too much of an issue. I think you remove the centre cap from the rotor, you'll see it staring you in the face. Then theres a bolt (close to 18mm) underneath it.
    Not sure if thats right..........it probably is way off.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Those prices are a little over inflated...
    Rotors -> RDA Standard & High Performance Disc Rotors
    Pads -> QFM Brake Pads
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Jun 2006
    I got new rotors and pads , regrease repack wheel bearings on front end done for $400
    It can be a pain in the ass to do if the bolts are seized ... which happens alot ..
    the bleed nipple on calipers can seize so thats more $$$
    $600 does seem alot .. call other places and tell them what you need done .. $500 would be fair for all that work.
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    For reference, I can do all 4 slotted rotors and new pads for $450.
    Visit my Facebook page
    vn executive
    Feb 2009
    frankston
    hey i have a vn s1 v6 and i replaced my brakes front and rear with just standard stuff i paid $25 for set of pads each front and rear
    and $40 per rotor
    so $210 all up and fitted it my self and there not that hard up to
  1. SV6 Brakes
    By ozgrumpy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-10-2008, 10:13 AM
  2. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  3. brakes
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-09-2006, 01:03 AM
  4. help with brakes
    By markandsam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2005, 07:37 AM
  5. Brakes
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2005, 07:42 AM
