I've got a series 2 1993 VP Calais and the temp gauge is playing up, I would be driving and it would randomly go hot and the temp gauge light would come on, although the car is not overheating at all, it would then just go back to normal after a minute or so.
Any ideas of what is causing this? I replaced the thermostat recently because mine was stuffed and it kept overheating, since then the car has been fine apart from the temp gauge going to hot randomly.
Any help is appreciated, thanks.
the cooling system bled properly? if not give that a shot. otherwise, it could be the inlet manifold gaskets. i had this problem with my vp and it was sucking up all the water and overheating and then it would be fine.
George
the left side hose goes into thermostat houseing that has the bleed screw .. yes ..
also leaving your heater on will help get more air out ... so let that warm up ..
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
Heater on full, start the car, let it warm up, undo bleed screw, keep topping rad up an squish the rad hose til liquid comes out the bleed screw, once it does it's bled properly
Mat
Originally Posted by garth
Okay, as of last night my car has been overheating, when it gets to hot the radiator will start making loud clunking noises, I've washed out the radiator a few times, bled it a few times, when I undo the radiator cap the water won't shoot out, instead it will come out in clunks, even after I've bled it and got all the air out, it will still clunk and make noises, I don't get it.
Here's a vid I uploaded so you guys can understand what I mean by the clunking:
YouTube - VP Radiator
Nevermind, all fixed, turned out to be the thermostat again grr.
