Hey just wondering would a vn manual wagon tailshaft fit on my sedan?? im using da manual conversion outta da wagon and fitting it on my sedan!!![]()
you have to split the tailshaft at the centre bearing and use the manual front half and the sedan rear half. the wagon rear rear half is slightly longer than the sedan one. This is exactly what i did when i did my manual conversion.
George
Thanks mate!!!!
If you lived here in Melbourne, I could do you a straight swap. I need a manual wagon tailshaft for my Statesman![]()
The 1972 HQ Kingswood
If it vibrates, you will need to get it balanced.
how much would dat cost to get it balanced? dats if it vibrates?
Around $150 assuming you'll need a new centre bearing. Also depends if you can remove the tailshaft and take it down to them yourself![]()
if you pull it out of the wagon you will see that there is two spacers under the center bearing you do not need to use it in a sedan thay are there to get the angle of the tail shaft right i think has something to do with the pinion angal in the wagon/ute
il have a look wen i pick up the wagon??
hey mate do you know if a vs tailshaft will fit into your vp coz i have one (manual sedan) and i need a manual wagon. do you know if the vn will fit into a vp wagon? swapsies?
