Results 1 to 12 of 12
Thread: Throttle Body
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default Throttle Body
    Okay so i got a new throttle body, its a v8 one and I was wondering how hard is it to change over the plug ons and stuff. Because the new one has none, for like the sensors and stuff, Also the top spring is that hard to take off? will it fly off when I remove it?
    Any help appreciated.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    its odd it dont have the applicable areas for the sensors as for the springs they wont fly of but you will have to re tension them when putting them back on im not sure why you bought a v8 tb and this is a point of contention so i expect it to be argued but the stock tb flows nearly to the max the engine can take unless you have head mods and rather large internal mods
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Its got holes but the other end of the plugs were removed for some reason. Hard to re tention the springs?
    Jun 2008
    golden beach
    Quote Originally Posted by markER717 View Post
    after you have taken it off of the original tb put it on the new one and rotate it by hand putting tension on it at the same time fitting the top plate and locking the ends of the spring in where they belong thats how i did mine im sure theirs probably a far easier way anyone care to share lol
    i get what ya meen its dead simple to change over the sensors coupe screws in each give the iac a clean wile its out
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Well its got the holes right, but the connections that are held in by 'torx' screws(need to borrow from work -.-)which I will just remove and swap with the v6 one, I suppose.
    Jun 2008
    golden beach
    i get what ya meen its dead simple to change over the sensors coupe screws in each give the iac a clean wile its out and a small flat screw driver will work with the torx screws
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Ah but I tried,, those f**kers were on tight I chipped the inside of the head when I tried it. lol
    Jun 2008
    golden beach
    lol get some pliers on them just to start turning them out get a good grip they will come lose (had to do it on the side of the road one night blew my iac apart gas backfire)
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Quote Originally Posted by rob drag racer View Post
    Ah thanks for all the help dude!
    Jun 2008
    golden beach
    no problems
    Jun 2008
    golden beach
    how did ya go ?
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    on everything swapped over, but it runs as rough as guts, like it sounded so bad it actually scared me.. 0.o sounded like the engine was gonna rumble right of the pay. lol So I will put stock one back on I spose hopefully all sensors and that work or mabye thats the problem?
  1. throttle body
    By JakeAA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 12:43 PM
  2. Throttle body
    By 38VNIT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 12:41 PM
  3. V8 throttle body
    By Cannon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2006, 05:01 AM
  4. should i buy this throttle body?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2005, 02:10 AM
  5. throttle body
    By pizzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2005, 03:20 PM
