Results 1 to 11 of 11
Thread: Help!!! Fuel pump problem
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    Exclamation Help!!! Fuel pump problem
    Okay, this is kinda a last hope here guys, I just replaced my fuel tank, put in my old pump and sender, and now for some reason, I start the engine, I get about 1-2 seconds of firing, then she dies (like running out of fuel) and the pump keeps running for a good 10-15 seconds after I turn the ignition off.
    I really need to figure this out ASAP as I kinda need the car running for more than a few seconds.
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    did you put the fuel pump and sender in the exact way it came out? as in the exact same bolt hole position? if not it wont be able to pick any fuel up to send to the motor.
    George
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    turns out from some extensive forum searching I came across this beauty of a post on a seperate thread I luckilly came across.
    Quote Originally Posted by xcop5l View Post
    pull out your fuel pump and have a look inside the tank with a torch (not a lighter hahahahahah) take note of where the lowest part of the pump is and then have a look at the baffel box. its a rectuangular box with no top on it inside the tank that the fuel pump sits in, if the fuel pump isint sitting in this box or the box is broken this will be your problem. if the box is broken you will need to get another fuel tank as you cant change the boxes over
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    so what was the problem? was it in properly as i said in my first post or was the baffle broken?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    you broke whose box george?
    as ben said in the quote, pull the hose off hte fuel line and check for fuel sperting out when priming. if none then you have no fuel pressure.. simple!
    cabot is offline cabs
    vr lexen
    Aug 2009
    s.a
    Default vr lexen fuel/vacuum issues?
    hi i own a vr lexcen and 4 a while it felt like every now and then it was getting held bak and didnt like reving over 3 grand turning it of and on semmed to fix it for about 20 mins and when i got low on fuel it sounded like crap that has eventually gotten worse and now it wont start straight away and cant put your foot down even half way and cant go under quater of a tank plz help
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    George, it was put in properly, right holes and all, however, even with the right positioning of the holes, the pump wasnt quite positioned right inside the tank, it took some wriggling and magic to get it to sit properly in the baffle and get the fuel pumping at the right pressure
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    Quote Originally Posted by cabot View Post
    thread stealer lol
    skruba
    VSII Statesman V6 96
    Jun 2009
    Hi not sure if anyone would know but i am having trouble with my car accelerating. The car starts fine but when i go to accelerate the car stutters. I find it hard to reach speeds over 80km without the car stuttering.
    Does anyone know what the problem could be? Fuel pump perhaps?
    VTEZN's Avatar
    VTEZN is offline TEAZN U
    1999 VT S Series 2 5 Speed
    Aug 2009
    hey guys sory to steal the thread but have some problems with my fuel pump. i recently replaced it with a brand spanking new pump im 100% sure the conections INSIDE the tank were correct. though the three hoses that lead outside the tank may have been mixed up. The problem im having is that it is hard to start takes me about 15 mins of cranking but she finaly goes. then when i get low on fueal every time i turn right and accelerate the car will conk almost as if its out of fuel but there is fuel in the tank. i own a 1999 VT S S2. if anyone can give me any tips i would be happy. tomorrow im dropping the tank and seeing wats wrong.
    Vp series 2
    Jun 2008
    you either broke the return hose off the swirlpot or did not reconnect it.
    Also check the fuel pump relay and fuse.
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. possible fuel pump problem? please help!!!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 04:54 PM
  3. Fuel Pump Problem?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:46 PM
  4. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
