Results 1 to 7 of 7
Thread: sump question
    tufcalais's Avatar
    tufcalais is offline I like boobs
    vs wagon (soon to be pimped)
    Jul 2009
    adelaide, SA
    Default sump question
    gday fellas hows it going?
    this is my first post on here
    i have a 91 vp v6 calais i need to change the sump as the retard who owned
    the car before me jacked the car up by the sump. i was wondering whether i need to lift the engine to do it?
    cheers guys
    '96 VS Commodore Equipe Sedan
    Apr 2009
    I am nearly sure that you will have to either lift the engine up or even take the engine out to do it. I can tell you for sure though, you can't replace the sump without at least lifting it
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    2 ways, pull motor out and swap it off car OR support motor with either a beam/crane, drop kframe and suspension gear and drop it that way.
    how bad is it dinted? i wouldn't bother if its not that bad, but if the pickup has been damaged then id be looking at replacing it and the pickup..
    probably a good idea to remove and clean out the oil pickup while the sumps off. should take 10 mins but save you trouble in the future.
    good luck!
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    If you're after a new one I can help you out. I work at Australian Specialty Racecraft (Site Sponsor, Have a look at the Sponsors part of the forum.) You don't have to lift the engine or drop the cross member, but it helps to. Jack the car up, Support your engine with a crane, undo all the bolts involved and drop the cross member, then reaching all the sump bolts it easy (unlike doing it without dropping the cross member.)
    PM me if you want to know more of our performance oilpans.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    Dec 2006
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    im dbating whether to get a recond 5 ltr and trans. this v6 is pretty tired...
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by tufcalais View Post
    do it, i sold my smashed 5L with trans, tail shaft, lsd full looms for $1500.
  1. dent in my sump?
    By mike49 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2009, 10:55 AM
  2. Oil Sump
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2008, 11:43 PM
  3. What is it? under the oil sump....
    By AlpineRaven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 05:30 AM
  4. oil sump
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 08:39 AM
  5. sump
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 01:05 PM
