Results 1 to 3 of 3
Thread: vn fuel pump
    vn wagon
    May 2009
    Default vn fuel pump
    which is the top of a vn pump i pulled it out and dont think i put it back in the right way thanks
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    You should see where the rubber hose comes to rest (without you touching it) and line it up with the steel line, and bobs your uncle!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Fuel pump VR Check it out
    I think they are all similar, the last pic on the right is the to pof the pump
    Reaper
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
