Results 1 to 2 of 2
Thread: Clutch pedal loose
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default Clutch pedal loose
    My clutch pedal is loose as in it can be moved from side to side... I know its not anything to do with the cable adjustment as thats all set good and the clutch operates fine..
    How do I fix the pedal having play from side to side (left to right) is it something like a worn bush in the pedal assembly or what?
    Thanks!
    2010 Yamaha R1 & 2000 VT SS
    May 2008
    Toowoomba
    its just the bolt at the top of the pedal, its a bit hard to get too but with a little persistence just tighten it but not too tight that you wont be able to push the pedal in lol
  1. Clutch pedal spring
    By dawg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2011, 05:12 PM
  2. t5 clutch pedal again
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 07:28 PM
  3. Wtb:vs Clutch Pedal
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2007, 12:43 PM
  4. Clutch Pedal Spring
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2005, 07:18 AM
  5. VR Clutch Pedal Vibrations
    By MuNtEd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2004, 08:35 PM
