Results 1 to 23 of 23
Thread: 308 into vp
    tufcalais's Avatar
    tufcalais is offline I like boobs
    vs wagon (soon to be pimped)
    Jul 2009
    adelaide, SA
    Question 308 into vp
    what will i need to put a 5 litre into a v6 vp?
    engine (duh) loom, trans, x member,diff, new shocks n springs, vt brakes
    anything else i forgot? i will be doing the conversion with my old man
    cheers lads
    VS Berlina 3.8
    Dec 2008
    What gearbox are you using? The 308 blocks have a trimatic bolt pattern wehreas the 304 blocks have the Chev turbo pattern.
    Are you actually using a 308 or a 304?
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    havent got the motor yet im saving for it. what u reckon is easiest to mount
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    Quote Originally Posted by hakhawk View Post
    304 coz they came in vp's. get a kfram and you're set for bolting one in
    what i can use v6 driveline?
    hakhawk's Avatar
    Jan 2005
    im talking about bolting it to the chassis. you will need a v8 gearbox and tailshaft to match.
    i suggest haveing a search through the site, many people have done the swap before
    Vt-Brrrlina is online now vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    engine and kframe to mount on it.. v8 gearbox, tailshaft
    computer and loom.
    dont go vt brakes go next one up ve brakes. bit bigger and are awesome..... close to same price
    springs...
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Vt-Brrrlina View Post
    computer and loom.
    springs...
    just a memcal will do even, delco 808 is the same for v6/v8
    can you even bolt VE brakes on? they'res a reason they have 16" wheels minimum
    VS Berlina 3.8
    Dec 2008
    I don't know why you think you need VT brakes anyway. The brake upgrade is nice, but they are not needed for the 5 litre conversion.
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    i like to have the slow to equal my go. plus i seen some nice slotted rotors pretty cheap...
    i would have to get newer hubs to upgrade though... or do they fit straight on?
    VP Executive R-spec
    Jan 2005
    Don't worry about the brakes, you can do that later, just get the engine in and running
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    no worries. i just need loom, memcal, k frame, v8 th700, tailshaft to get it running?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    will get you a good start with that, you will need a radiator aswell.
    Reaper
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    cool well ill have some stuff for sale then. the calais has a near new radiator in it atm. oh and ive got my 4l60e from my vt that i crashed any offers? been serviced 1 month before crash oil was good colour no slippage
  15. #15
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Just buy a smashed V8 VN/VP and transfer all the bits over. That way, you know you have everything you need...You will pick up a smashed VN/VP for $1500 or less, you will be paying that for a motor alone at wrecking yard prices!
  16. #16
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by tufcalais View Post
    V6 and V8 radiators are different.
    This is the easiest way. Going back and forth from the wreckers trying to find odd bits and pieces one at a time will become expensive.
  17. #17
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    cool ill have to start looking for smashed vn/p then.
    I meant ill have some parts to sell when i do the conversion
  18. #18
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Don't know where your from but i find a lot of cheapies at the auctions round Melbourne and eBay!
  19. #19
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
  20. #20
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
  21. #21
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    Quote Originally Posted by _R_J_K_ View Post
    All commodores from Vn onwards use a Turbo 700.
  22. #22
    VP Executive R-spec
    Jan 2005
    also will i need an instrument cluster?
    There's a how-to somewhere on changing the resistors on the tacho to suit a V8
  23. #23
    tufcalais's Avatar
    Jul 2009
    adelaide, SA
    sweet as. anyone got a v8 they wanna give me?
