Hi Guys and Girls, i have a VP Commodore, its got WILDCAT headers, 2.5"HF Cat, 2.5" Cat Back mandrel bent Exhaust with a LUKEY muffler, i wanna go abit louder and was wondering if i just cut out my muffler and weld a pipe into its place, What do u guys think, will it sound good, how loud will it be ?. Thanks.![]()
VP's ARE THE BEST
if u take the muffler out it it will be loud and clappy/harsh. whack a hotdog muffler in its place it should tone down the harshness but still be pretty loud. u dont want it sounding like the ghetto pov pack pieces of shit getting around now do u? my mate did it with his au falcon it sounded like shit
HORSEPOWER- Some is good, more is better and too much is just enough!!
When in doubt,USE FORCE!
A Hotdog will make it louder & especially at the rear make it DRONE like a mother complaining to a child...
Originally Posted by garth
Is your exhaust single or dual muffler?
Put a hotdog in, in place of the centre muffler, & you can either straight pipe the rear, or put a muffler on it. up to you really
Both my V6 & V8 have a similar setup, hotdog in middle = less drone.
if you cut out the muffler on that setup then it would be a nearly straight exhaust. that's far too loud for normal road use, draws way too much attention even if it sounds good.
a cannon will barely muffle it and will increase the drone, you will need a decent cannon to within the legal limit. well at least in vic (limit is 90db).
You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
My advice is to leave it like it is, quiet.
Loud exhuasts on a V6 sound shithouse and say to the world that you wanted a V8 but couldn't afford it and settled for a V6.
Yep freeway driving sucks with a straight thru....maybe get a electric valve muffler so you can bypass exhaust straight out to impress the birds, and closed through the muffler when freeway driving....
HAHAHAHAHAHAHAHA I hear them all the time round my area. if u dont have at least one muffler on ur exhaust the piggers WILLpull u over then bend u over when they test it. plus it will sound tryhardish when u give it some stick. probly sound good at idle. check out a local exhaust shop for a price on a hotdog tho. your exhaust should sound alright anyway dude u got extractors+2.5 inch.
got single muffler, in the middle, im gonna cut it out and put a hotdog in its place, also what if i put a resonator on the rear side of the diff, will this tone it down a little bit but make a nicer note and be a bit louder then the havin the muffler, so hotdog then resonater, what you guys think ?
VP's ARE THE BEST
i have a VE, it has extractors, 2.5" mandrel system from cats. It originally had 2 mufflers, a mid and a rear. I have recently removed the rear - much louder and sounds alright, if it had no mid, it would sound real loud and real shite. I feel as is it is a little droney if it sits between 2000 and 2200, outside that it sounds alright and burbles a bit coming off acceleration from 5000rpm down.
I agree a hotdog is prob only option, straight through will drive you nuts.
JC.
I would put the hotdog on in the middle and put another one after the diff. It will take the sharp bark out of it and make it more of a growl with no droning! Good luck with it dude!
Cheers............................Pete!
So with 2 hotdog, 1 in the middle, 1 after diff, that will still be louder then the muffler but should be sweet?, i've brought 1 hotdog so i'm just gonna cut out the muffler and put it in the middle, i'll see what its like to weather i go another one, what about a resonator after the diff ?.
VP's ARE THE BEST
Mate, you can actually get an offset muffler that is straight through but keeps the stock look. I have one on my Patrol and it sounds sweet with a 3" system, not loud but it still demands to be noticed.
Cheers........................Pete!
I think thats what mine is but my car is just really quiet, i have mates with just cat backs, smae car as mine and theres are louder, and i have extractors and fat cat. But i enjoy experimenting on my car so i'll just play it by ear, edit it till it's perfect, should be sweet i recon.![]()
VP's ARE THE BEST
get a cannon and a middle resonator designed to cut out some of the drone. Should be good for daily use.
However, i love the sound of a straight VN but that's just me.
VP's ARE THE BEST
I had a hotdog where my centre muffler was on my old car at one stage. Sounded dreadful, was really offensive and barky. Sounded like a 4 cylinder on steroids. Then i got pulled over and cautioned about it the day before it was going back in to the exhaust shop to have the muffler put back on.
It was really tinny and sounded terrible. I felt sorry for the people driving around me on the road.
Originally Posted by wikky
