Results 1 to 2 of 2
Thread: VN calais wont start flashing hazards
    VN Calais
    Aug 2009
    Default VN calais wont start flashing hazards
    hey. i was having problems with my vn calais it would randomly stop every now and then, the engine light would come on and a ticking noise would start in the dash some where. I would just let it sit unit the ticking stopped then the car would start fine. I replaced the crank angle sensor and that didnt help and then replaced the coil pack. It was working fine until now, it wont start at all. The hazards are flashing and the car is turning over but wont fire. I did a Assembly Line Diagnostic Link test and the first reading i got was 12 but then when i did it again it said 41 meaning the crank angle sensor. I have given the fuel pump a bash but still wont fire. any ideas
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have you reset the codes after changing the CAS?
    Cause it could be an old code.
  1. HELP!! VS 5lt Calais will crank but wont start
    By ashbox in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2009, 09:29 AM
  2. VN calais wont start
    By 1990VNcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2009, 04:24 PM
  3. The Calais wont start..
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2009, 10:05 PM
  4. 88 VN Calais wont start
    By jrod_666 in forum Electrical Wiring / Questions
    Last Post: 24-07-2006, 05:36 PM
  5. VN Calais Wont Start but will Turn over
    By mrhaboobi in forum Electrical Wiring / Questions
    Last Post: 20-09-2005, 09:18 PM
