Results 1 to 9 of 9
Thread: 89 vn over heating
    89 VN COMMODORE V6
    Aug 2009
    Default 89 vn over heating
    Hi guys
    just registered for this site as it looks like its going to be very handy, now onto my problem
    i just replaced a part ( not even sure what its called lol) it mount to the inside wheel hub and has something to do with water flow it was leaking really bad so i figured it may have been why the car was over heating but i just replaced it today not a single drop is leaking but around 1/4 way up the temp gauge the car is already very hot and water is boiling, i am not the best with engines but i know a little any soultions as to the possible cause would be great
    Vn Exec
    Mar 2009
    quite possible that ur thermostat is fkd if that is the case - its something that needs a bit more explanation i rkn
    '90 S1 VN 3.8L A4 Wagon
    Feb 2009
    new thermostat. a bit of work to replace on S1 VNs but not impossible.
    thermostats are like $10-$20 from autobarn i think and make sure you get the lower then stock. I have an ~80c thermo now, instead of ~90c. With the radiator fan on all the time, car never gets over 2 marks.
    You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
    89 VN COMMODORE V6
    Aug 2009
    thinking about it even when the car was really hot i dont think the fan even came on at all, i'll have to dbl check tomorrow but i am 90% sue it never came on, could this be a reason?
    Feb 2009
    easy way to test.
    -open the bonnet
    -start the car, let it run till it starts to over heat
    -place hand on the top left hose that goes into the radiator
    -if cold, then thermostat is broken, replace.
    -if warm then im not sure why it's overheating, try by-passing the FAN thermostat thus forcing the fan always on.
    -report results.
    89 VN COMMODORE V6
    Aug 2009
    yeah the hose is hot, how do i go about bypassing the fan so its allways on?
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Thermostats are worth $7
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Feb 2009
    Quote Originally Posted by andrew86 View Post
    you have to locate the relay and run a wire before it, i think. i haven't done it myself, my dad did so not 100% sure.
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    Quote Originally Posted by Peter89 View Post
    I can personally state that a constantly running thermo is not adviseable, as it will eventually melt your thermo fan relay... thankfully (in my case) the air-con relay is identical. And i have no aircon setup anyways, so an easy replacement.
    Better to get the thermo switch setup to come on earlier, as its still on/off, and also wont drain power when trying to start the car...
  1. over heating
    By crew.man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2008, 07:10 PM
  2. No heating
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 12:29 AM
  3. heating
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 08:31 PM
  4. over heating 308
    By sk00bs in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-04-2006, 09:25 PM
  5. VS heating up...
    By Gobbles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2004, 10:07 AM
