Results 1 to 17 of 17
Thread: Diff!
    1996 VS Caprice V8. 1996 Proton satria.
    Jul 2008
    Seaford, Victoria.
    Default Diff!
    My diff has been making a metal on metal rubbing/whineing sound for a while now, and yesterday started knocking.
    (my guess would be carrier bearings?)
    And then today, i gave it a punch from the lights, and as soon as second snapped, BANG followed by alot more banging ald clunking until i got home. I pulled up to lights at the seaford road off ramp, and came to a complete stop. then once i tried to take off, nothing, just revving. so i chucked it in reverse and then threw it into first as i was rolling and i guess it caught the gears and i was moving again
    Like i said, my guess is the carrier bearings.. would i be correct?
    The all new TATA Nano, India's $3000 low cost car, Runs on Chicken Vindaloo!
    VT spac super6
    Nov 2008
    Riverton sa
    Jul 2008
    Seaford, Victoria.
    Quote Originally Posted by HARVZ-6 View Post
    id say all the gears are probably destroyed now aswell
    My thoughts exactly. i weighed up the cost wether to drive it home or get it towed. probably chose the wrong one.
    The stato has a very harsh shiftkit in it, which has been in the car for about 40,000K's and the car has done 371,000, first to second snap nearly gives you whiplash so i think it was time for the diff to give way (with all the burnouts the old owner did not a great help)
    Basicly, what would i be looking for in a diff that would last, with better acceleration on apprentice wages? or would it be better to go a standard diff, and get the pressure in the auto turned down a little?
    vx/vp berlina
    Jun 2009
    wollongong
    VN
    Mar 2009
    If your cars only putting out stock power would the diff really be taking that much stress????
    And if it is the gears that are taking a beating why don't you just get them harden??
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    the diffs are weak.. im on my 4th with a more or less stock engine. at $750 for a full rebuild/install
    If it's the planetaries in the diff then a spool will stop that from happening but will cause other shit like breaking the cv's once a year lol
    VN
    Mar 2009
    VX Executive A4
    Dec 2005
    Brisbane Northside
    Jul 2008
    Seaford, Victoria.
    Well, it's stock as a rock apart from the apparent $2400 spent on the auto.
    I think i'm going to get the pressure turned down a little.
    I don't know why anyone would spend that amount on building a tough auto and not upgrade the diff or the tail shaft.
    If i put a 4.11 in with a spool, what sort of revvs would i be getting at 100 k's an hour?
  10. Default
    4.11s? there are some calculations somewhere - ****ed if i can find them though! my guess is around 2400-2500rpm at 100km/h
    Quote Originally Posted by zai View Post
    I am not sutpid
    VP Executive R-spec
    Jan 2005
    4.11 are uselss in a street car with a an engine that makes power as low as the 304 does. 3.9's are the MAX. I don't know how you managed to break a diff in a VQ with a stock motor but I would put it down to bad luck / or no oil or something. The diffs are alot stronger than that so I wouldn't worry about it happening again no matter how hard you make it shift, the IRS cradle will break ages before anything else does
    Jul 2008
    Seaford, Victoria.
    Ah i see. How come? What exactly would i experiance with 4.11's? i'm after quicker take off, so i guess i should take your advice and go 3.9's
    I pulled the diff out today and had a look inside, and the crown's chipped. not too bad, but bad enough, so it's new diff time
    Cheers.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    a spool kills drivability, harder to do u-turns, use set of tyres a month for the rear lol, alot of axle bind and low speed, but yeah good fun when its wet
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by vn_v6 View Post
    I beg to differ
    The 1972 HQ Kingswood
  15. #15
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    oh god here we go again i hope stealthy don't see this lol
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  16. #16
    Vp series 2
    Jun 2008
    stealthy has been proved wrong but won't admit it.
    assuming it is a lsd, i have been seeing a lot of them were the pinion bearing have let go.
    This is probably what has happened to yours.
    Likley causes are
    1 old age
    2 oil has failed due to extra requirement of being lsd
    3 lsd puts more pressure on pinion when it locks causing faster wear.
    either way if it is live axle just get a secondhand one and jamin and maybe swap the lsd centre over.
    Takes a bit of skill to get the shims right. make sure you use the gear set from the replacement diff.
    irs, same deal.
    I have been paying $40 for std diffs at the dump up here.
  17. #17
    Jun 2008
    golden beach
    Quote Originally Posted by centy View Post
    Likley causes are
    1 old age
    irs, same deal.
    i must admit i picked up a vn running for 90$ so yeh either a center or a cheep diff aint to hard to find
  1. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  2. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  3. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  4. WTB: 3.73 Diff Gears Suit VS Diff
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 02:51 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
