Results 1 to 8 of 8
Thread: Cable
    VN
    Mar 2009
    Default Cable
    Heyyy all
    In light of me having blown my big end bearing and deciding to put in a new engine i decided to buy a vn wagon for $80 and take the engine and trans out and put the engine into my car.
    I was taking the engine and trans out and just as the eninge and trans were coming out i saw that a cable which usally is connected to the throttle goes into the trans
    I was just wondering if any1 knew what It is and what it does.
    Cheers Tyrone
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Kick down cable.... Makes the gearbox kick down a gear when a certain amount of throttle is applied, i.e Going un steep hills.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VN
    Mar 2009
    AHHHHHH fairo
    Iv always wonderd how the tans does that.
    What happens when you convert a auto to manual?
    What happens to that cable?
    cheers tyrone
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by freddie142 View Post
    AHHHHHH fairo
    cheers tyrone
    It vanishes lol. Its not needed, for obvious reasons, so it just gets disconnected.
    VN
    Mar 2009
    ohk fair enough.
    Is there any adjusting that can be done the cable or is it unadjsutable?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    ohk fair enough.
    It can be adjusted, but all it will do is change at what throttle percentage it kicks down, if you set it to low its going to be a royal pain in the ass, if you set it to high, you will be using more throttle to get it to kick down.
    VN
    Mar 2009
    Black VN MANUAL
    Feb 2007
    Top of Vic
    No, if you disconnect it from the bracket that its sitting on the elbo near the Throttle body you will have to adjust it, if you dont know how to adjust it i suggest leaving it alone lol
    ~ VN POWER ~ Click the scales
  1. 95 lexcen bonnet cable will a VR cable fit?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 04:19 PM
  2. Diagnostics Cable USB
    By SSbeast in forum Electrical Wiring / Questions
    Last Post: 20-12-2006, 07:55 AM
  3. kick down cable?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2006, 02:16 AM
  4. Clutch Cable on a V6
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 01:29 PM
  5. rem cable
    By ben k in forum Car Audio
    Last Post: 20-04-2006, 05:45 PM
