Results 1 to 7 of 7
Thread: boot release not working?
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Default boot release not working?
    hi all, i have a vn v6 1990, and the boot release button stopped working, wheres the fuse for this?, ive checked plugs and all that still nto working, hate using key now
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    do you mean the lever next to the seat? or do you have it on the keyring?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Is it an electronic boot release? It's possible the actuator in the boot is dead. Does the key work? Or is the whole latch mechanism jammed?
    The 1972 HQ Kingswood
    vn_v6's Avatar
    Aug 2009
    victoria
    its the button in the glove box, there is no manual one? and the key works fine
    Morton's Avatar
    May 2006
    Probably a dead actuator then. It's located in the boot. Replace
    vn_v6's Avatar
    Aug 2009
    victoria
    Quote Originally Posted by Morton View Post
    thing is it used to work, but it was dodgey, like sometime you had to press down on the boot a bit cause it would make a noise but not open, now no noise no nothing,
    how much is an actuator?
    Morton's Avatar
    May 2006
    You're probably looking at about $20 for a second handy on ebay, there's quite a few from time to time. Sounds like the release wasn't properly aligned (hence the struggle to open it sometimes), and the extra effort has worn down and broken the actuator.
    If you can't find one on ebay, try a local wrecker. There's bound to be a calais somewhere.
  1. VP Calais remote boot release not working
    By fnlow1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2011, 10:07 PM
  2. boot release
    By VNDUMP"D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2009, 03:58 PM
  3. Boot release fix???
    By GH05T in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 03:20 PM
  4. Boot Release not Releasing Boot
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 07:30 PM
  5. vn boot release
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2005, 08:03 AM
