Results 1 to 18 of 18
Thread: Awww... I got a Fuse problem , Need help .. lol :(
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Red face Awww... I got a Fuse problem , Need help .. lol :(
    Hey guys!
    Its me again ... Was just driving today, and just before.. I wanted to go out Night Driving. BUT, my Parker Lights were not working.. So I checked the Fuse Board, and yep.. I found the problem .. but lol, the bottom half of the Ruse Rod is melted inside the Fuse Slot..
    Already tired to get some tweezers to pull it out, no luck. So, Im wondering.. Is there any way I can re-wire it or somthin to get me Parker Lights working?? without seeing a leccy .. Or I can't go nigh driving for a bit hehehe.
    The fuse was supposed to be in Slot1 (Trip Computer. Head Unit, P/lamps) had a 30 fuse in it!!!! Instead of a 15A .. I have checked all me other fuses to see if they are correct and some wernt.. so there all good now
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Do you have to have your parkers for night driving?
    You could bypass the fuse, but the fact that it blew/melted means it is drawing too much current so there could be a short somewhere
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Sadly, yes. P/Lamps turn on your Dash Lights and License Plate Tag Lights.
    As for the current, I dont think it is. Im just a lil pissed to see a 30A fuse in it instead of a 15A .
    As how to Bypass the fuse, how would I go around that? for it to work safely etc
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    ALSO! lol. I've had the car 6months, and never had any issues with it before
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    if you really can't remove the existing fuse by force, unscrew the fuse panel and cut the wires for that fuse off from the back of the panel **, replace with an insulated in-line fuse avail from repco, supercheap ect ect and will run the same style fuse for ya, so not much will change except the fuse location.
    Also, this is one of those times (like all times ) where simply twisting and inso tape won't suffice, be sure to use solder, terminals and heat shrink to keep it neat and ensure it will continue to work...
    ** one of those wires will be live positive from the battery and will have no fuse link protection, be carefull not to short it if you're too lazy to disconnect your battery when doing this..
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Thank's Will defiantly be doin this .. Hope all goes well, and I will defiantly disconnect the battery hehe
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Ok guys! Update for this problem.
    I've got myself an Inline Fuse, cut the wires etc etc.. And have Solderd them to where they should go.
    IT WORKS!!
    But, I will be checking it over to see if anything happens (Fire..etc)
    Thanks again!
    varies
    Jul 2008
    gone
    Quote Originally Posted by Dumster View Post
    IT WORKS!!
    Thanks again!
    well, if you've insulated your solder joins, and used the right size fuse, the chance of fire is heavily reduced...
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    most cases of actual melted fuses in the fuse box is loose contacts generating heat in the fuse should be sweet now
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    For future references; By-passing the fuse isn't a good idea. The fuse is used so that when theres a problem the weakest link will blow (the fuse) so if the fuse blew, you might end up blowing up something else.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Most likely, once I've got new Struts in, I'll get the car down to a Auto Leccy and make sure it's OK. I'd prefer to use the Fuse Slot.. But for now, I can't
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ive replaced many headlight etc fuses in the vn-vp fusebox before its quite common i normally just use crimp on spade terminals and a blade fuse works great just they dont fit in a melted mess too easy LOL
    varies
    Jul 2008
    gone
    Quote Originally Posted by markER717 View Post
    uhhh, no-ones "bypassed" any fuses, just running a blade fuse in a different location due to the housing being melted. This is a common problem, and there's nothing wrong by running this setup, it's still a fused link, it's just in a different location.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Thought I'd throw a pic up so you can all see what I done, and have a squiz at the melted fuse slot
  15. #15
    varies
    Jul 2008
    gone
    Good job, glad you got it fixed without a whole bunch of drama's. I assume you've heatshrinked and soldered the connections out of view?
    Should last ya a long time and give you no more trouble, just have a poke around the devices running off that fuse to make sure it's not gonna get blown again. (30A was a bit much, and what a nice cook-off you had there)
    Trip computer and parkers should be fine, but if you've got an aftermarket headunit, i'd look at running it's own dedicated feed anyways.
  16. #16
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I got this same issue with my A/c fuse, its all melted around it. It blows about twice a year so i havnt bothered too much with it but this is a easy solution to the problem and might be worth my while to do this soon. Rep points....if i could.
    Reaper
  17. #17
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Yep , all Heat Shrinked ... Mind you, it was a hell of a job to do tho.. Tight space lol.
    During the time I did this all.. I was VERY frightend that I may 'F' the whole thing up hehe
    As for the cause, Im yet to find why .. However, I do remember.. A mate of mine hooked up a Amp, and unfortunately we think it may have caused it.. But, we are not game to use it again - I will aslo be checkin out the cables behind the Head Unit on the weekend, Just to be safe! Dont want my VP dead yet heheheh
    As for runnin the head Unit with its own dedicated feed.. Im almost 100% sure I will be doing it, to avoid a more serious issue
    ALSO! If anyone has any Q's on how to Install a Inline Fuse + Heat shrink etc etc, please let me know
    Thanks again Coast, I owe ya!
  18. #18
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Quote Originally Posted by VrWagz1 View Post
    I would suggest do an Inline Fuse job. BUT, it's if blowin twice a year .. Then I'd be checking all your wiring behind your A/C controls. However, it's strange that an A/C would keep blowing its Fuse :S :S
    If you can give me some more info, I might be able to assist you better
  1. head unit fuse problem.
    By Smallies in forum Car Audio
    Last Post: 17-04-2009, 06:15 PM
  2. Weird Problem Blowing A Fuse
    By ICUBYE in forum Electrical Wiring / Questions
    Last Post: 12-07-2006, 03:47 PM
  3. Awww Nuts!
    By ElDubya in forum Jokes/Humour
    Last Post: 23-06-2006, 07:07 PM
  4. Major Fuse problem
    By vs girl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 06:22 AM
  5. *URGENT HELP* - Fuse Problem
    By Fatboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2004, 02:30 PM
