Results 1 to 10 of 10
Thread: Need DIY rear brakes
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Need DIY rear brakes
    Anyone got a DIY repair rear brake calipers and repair and replace on the rear rotors please
    Real cars don't power the front wheels, they lift them
    Vp series 2
    Jun 2008
    VT SS 5.7
    Mar 2005
    Goulburn
    the rear rotors are scratched beyond repair so ima replace them just not sure how to remove the rear rotors
    Vp series 2
    Jun 2008
    unbolt calipers and move them out of the way.
    loosen handbrake.
    tap back of rotors and the will fall off.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Make sure handbrake is off and the other wheels are chocked.
    Illegitimi Non Carborundum
    VT SS 5.7
    Mar 2005
    Goulburn
    arr sweet thank you, oww 1 last question wat should i go for a set of protex brand rotors or DBA ?not slotted or drilled
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I can do you a good deal on the RDA slotted or slotted and dimpled.
    Visit my Facebook page
    vn executive
    Feb 2009
    frankston
    at my work i ordered sum dba rotors just standard ones from a place called betterbrakes for $42 each and 25 for pads with trade ofcourse but it cant be that much different
    Vp series 2
    Jun 2008
    back brakes do very little.
    Unless you have upgraded the front brakes standard is the way to go.
    You don't want the back locking up all the time.
    VN V6 wagon
    Mar 2005
    Yeah, I wouldn't bother putting too much effort into the rears. Just a new set of standard discs. put a kit through the calipers.
  1. Rear brakes
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 01:21 PM
  2. VT Rear Brakes To VN?
    By Dan355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2008, 03:46 PM
  3. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  4. vt rear brakes
    By briannon2002 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2005, 04:59 PM
