hey guys i was trying to post a thing in the wanted section put i can t yet i was just wondering if any one had a s1 6 bolt v6 flywheel thanks i live in vic near frankston if theres anyone near there thanks
im useing a s1 auto motor i got told u had to get a certin one thanks
you wont find one to fit the auto engine unless you buy the expensive custom built ones or an adaptor there is a thread on the crank issues on here will be in the v6 developement and modification forum
mate it would be better in the long run to replace the engine aswell with a later model one.
Assuming you have a convesion allready the cost of a adaptor and another flywheel would be more then a vr engine would cost you.
Azzfox has one
V6 Crankshaft Info
The complete Vn-Vr Manual Conversion Guide.
I connveted mine (S1 VN Auto) to manual, all the info you need in those to threads.
The Daily VN T5V6
355 VN GRP A REP
I have an 8-bolt flywheel.
Buuuuuttt.... I came across this on ebay. Might be worth watching.
vn series 1 manual flywheel to convert your auto motor - eBay Manual Transmission, Transmission, Car Parts, Accessories, Cars, Bikes, Boats. (end time 23-Aug-09 13:58:39 AEST)
Its the same setup Im currently running, but the S2 8-bolt version. I bought it for $395 brand new with bolts and spigot bush included so hes lying about the $500 bit. Oh, and you will still need the manual starter motor. Aaaand modify the inspection cover so it doesnt rub on the flexplate (as seen in pic).![]()
