gday fellas just wondering what temp the thermo fan supposed to come on?
to make it interesting can i have that in celcius?i think that is spelled right.
also would the temp sender for the computer be the same on vr motors as whats in the vn?
reason being ive replaced the motor with a vn motor and the fan hasnt come on yet and wanted to check with an accurate dial gauge put into the radiator
thanx
depends what tune you are running as to what temp the fan kicks in some are higher than others checking temp in the radiator wont be too accurate you need to check the temp on the engine side of the thermostat to get a true reading easiest way is with a laptop connected to the diagnostics port
